A 7-in-1 modular cleaning system with a clear philosophy: Transform – Power On – Clean
The Dreame H15 Mix is designed with a different approach compared to classic floor washers: it is not just a machine for washing floors, but a complete and modular cleaning system, designed to cover all household needs with a single device.
The 7-in-1 concept is not just a slogan, but is based on a technical platform in which the removable motor and battery become the core of multiple operating configurations, while always maintaining high performance since each of the three main devices is of high quality.
The idea behind it is clear: fewer devices to buy separately, less clutter, and more continuous and consistent cleaning throughout the home.
Modular architecture: the real value of the H15 Mix
From a design standpoint, the H15 Mix stands out for its intelligent modular architecture. The motor and battery can be detached in just a few seconds and reused across multiple configurations: wet & dry floor washer, cordless/portable vacuum cleaner, and a dedicated wash & vacuum cleaner for upholstery, carpets, and rugs.
This allows you to switch extremely easily from cleaning hard floors to cleaning:
In everyday use, the advantage is greater continuity in cleaning, with everything at hand, taking up little space and easily transformable, especially in modern homes with complex surfaces and needs.
MODULE 1: WET/DRY FLOOR WASHER
Edge cleaning: GapFree™ AI DescendReach
One of the historical limitations of floor washers has always been cleaning along edges. Dreame tackles this problem with the GapFree™ AI DescendReach system, a robotic arm that automatically lowers in about 0.2 seconds during backward movement.
Beyond the commercial term “AI,” the system combines a sensor in contact with the floor and mechanical components to achieve a practical result: edge cleaning on three sides, including the front. In practice, the distance from the baseboard becomes almost zero and dirt is intercepted even at the front edge.
This significantly reduces the need for manual touch-ups and is particularly useful along baseboards, corners, and tight spaces. On the rest of the surface it works excellently on smooth, regular floors (imagine it like a squeegee), while on rustic, irregular floors or those with pronounced grout lines it tends to leave some water buildup.
Like any modern floor washer, it can be tilted to 180° with a brush head height of 10.6 cm and 14 cm for the main body, allowing cleaning under beds, sofas, and low furniture.
Suction power and intelligent dirt management
With power up to 23,000 Pa and a brush rotating at 480 rpm, the H15 Mix positions itself in the upper range of the multifunction wet & dry segment. This value allows it to handle, without difficulty and with a single device: fine dust, dry dirt, liquids, and heavier debris.
During floor washing, the system always uses clean water on every pass, preventing the redistribution of already collected dirt. The level of dirt is detected via an RGB optical sensor and displayed on the LED screen through colors, allowing the machine to automatically adjust cleaning intensity.
The result is more uniform cleaning that adapts to the actual level of dirt and improved energy management.
Automatic detergent dosing: fewer streaks, more control
One often overlooked aspect is detergent management: the risk is always using too much, causing streaks and buildup, increasing costs, and risking damage to the machine. The H15 Mix solves this by integrating an intelligent dosing system that varies concentration approximately from 1:200 to 1:30 based on detected dirt.
This approach has several practical advantages: detergent is used only when truly needed, streaks and chemical residues are reduced, cleaning is more uniform, and the machine remains protected.
It is a more “scientific” and precise solution compared to manual dosing, which often leads to waste, buildup, or worse.
TangleCut™ 2.0: active removal of hair and pet fur
TangleCut™ 2.0 technology mechanically addresses one of the most common problems in modern homes: hair and pet fur wrapping around the roller. The flexible scraper with a comb-like structure intercepts and cuts strands before they can create tangles.
In real use, this means greatly reduced maintenance with more consistent performance over time, solving a major issue in homes with pets and long hair. It is a technical detail that has a strong impact on everyday experience.
ThermoTub™: real hygiene and automated maintenance
Automatic maintenance is one of the strongest points of the H15 Mix project. The ThermoTub™ system washes the brush by immersion in hot water at 100 °C, heated by a metal plate in the base, ensuring complete coverage of the roller and internal ducts.
This is followed by controlled drying:
fast, 5 minutes at 90 °C, when time is limited
quieter, 30 minutes at 85 °C, for routine maintenance
MODULE 2: CORDLESS / PORTABLE VACUUM CLEANER
Cordless vacuum: not just a simple accessory
The vacuum mode of the H15 Mix is not a secondary add-on, but a true full cordless vacuum cleaner. It uses the same powerful motor as the wet & dry system and achieves performance comparable to standalone devices; while not among the most powerful on the market, declaring 100 AirWatt, it performs its task well.
With a weight of about 2.2 kg in vacuum configuration and the PowerAlign™ handle, weight distribution is well balanced and reduces wrist fatigue. This makes it suitable both for deep cleaning and quick daily cleanups.
The multisurface brush is also equipped with an anti-tangle system and CelesTect™ illumination, which improves visibility of fine dirt on hard floors and carpets, increasing effectiveness and precision especially in low-light environments.
Like the best vacuum cleaners, it is equipped with a mini electric brush for sofas, car seats, and mattresses, and a multifunction extendable and flexible crevice tool.
Equipped with a 5-stage AirGuard™ cyclonic filtration system, it filters up to 99.95% of fine dust and allergens and is washable for easy maintenance.
MODULE 3: WASH & VAC CLEANER FOR CARPETS/RUGS AND UPHOLSTERY
Carpet and rug cleaning: a dedicated, professional approach
One of the elements that most distinguishes the H15 Mix from other combo systems is the presence of a dedicated portable wash & vacuum cleaner for carpets and rugs. Here the goal is not just vacuuming, but treating dirt deep down, with dedicated detergent and hot water when needed, while reducing residual moisture.
The system combines a targeted jet of detergent solution with dedicated suction up to 19,000 Pa; the declared residual moisture of around 5% promotes quick drying.
In addition, it supports the use of hot water up to 60 °C (which must be added manually, as the device does not heat it itself), improving effectiveness on stubborn stains and greasy dirt. This makes it suitable not only for carpets and rugs, but also for sofas, armchairs, mattresses, and car interiors.
After cleaning carpets and upholstery, hose maintenance is often a critical point. Dreame has integrated automatic cleaning of the flexible hose with a single click, just insert the dedicated cover, reducing the risk of stagnation and bad odors.
Extended autonomy and energy management
In floor washer mode, battery life reaches up to 65 minutes; 75 minutes in vacuum mode and 45 minutes in portable wash/dry mode. The removable battery represents a concrete technical advantage, as with an additional battery (available for separate purchase) it is possible to continue cleaning without interruptions, making the system suitable for long sessions and large spaces.
With only the supplied battery, some basic energy planning is required since the same battery is shared; the battery is recharged directly by the floor washer when placed on the base.
DreameHome app and advanced control
Through the DreameHome app, it is possible to intuitively yet advancedly manage suction power, water flow, and the washing and drying cycles of the floor washer. With convenient maintenance reminders, OTA firmware updates, and usage statistics, all without overcomplicating the user experience.
In this video, I show the Dreame H15 Mix in real use, focusing on everyday cleaning:
Conclusion
The Dreame H15 Mix is not just an advanced combo floor washer, but a complete cleaning system designed to adapt to floors, elevated areas, carpets, upholstery, and car interiors. The combination of modular architecture, power, effective cleaning, intelligent management of dirt and maintenance makes it a particularly comprehensive solution.
It is not an entry-level product with its €899 price, but considering that with a single expense you get three solid devices, and while the market pushes toward fragmentation of smart devices, here the approach goes against the trend: a single, modular, and easily manageable system, designed for those who want simplicity, efficiency, and control in one solution. The H15 Mix represents the only proposal of this kind currently available in the Dreame catalog and on the market, and all things considered, it also offers good value.
