In 2024, AI technology in smartphones has become commonplace. Alongside their smartphone development efforts, Meizu is integrating AI into other products. They’ve utilized flagship chipsets to develop coaxial ring-iron units and launched their latest generation of true wireless noise-canceling earphones, the Meizu Live AI, achieving comprehensive AI integration across their product lineup.
Design
Design: Ergonomic with handle design, grooves fit comfortably in ears, minimal foreign object sensation
Touch Controls: Thick handle, pinch front/back for play/pause or track change, slide up/down for volume adjustment
User Experience
Noise Isolation: Significant in office environments
Intelligent Noise-Cancelling: Auto-adjusts to adapt to different environments
Battery Life: Up to 5.5 hours with noise-canceling on, 7 hours with it off, additional 22 hours with charging case
Sound Performance
Driver Combination: 11mm dynamic driver + 5mm LIVE PRO balanced armature driver
Sound Optimization: Lao’s best listening curve
AI Technology: “AI Dynamic Listening” custom ear sound field technology
Listening Experience
Tailored for pop music, clear high frequencies, full low frequencies, excellent detail and resolution
Soundstage: Natural, well-handled instrument decay
Technical Specifications
Main Chipset: Hengxuan BES2600Z, supports Bluetooth 5.3 and LHDC encoding
Lossless Transmission: Up to 24bit 192kHz in LHDC mode
Bluetooth Stability: Excellent, supports Hi-Res Audio
Noise-Cancelling Chipset: Sony CXD3784, supports multi-level noise reduction and intelligent adjustment
Noise Reduction Depth: Up to 45dB
What are your thoughts on the MEIZU Live AI earphones? Please share your comments and reviews with us!
