The Nubia New Sound C1 Bluetooth Earbuds provide a solid experience for everyday audio use. First, the sound quality is very good on these tiny buds. I noticed that my songs with deep base tones sounded well on these audio devices. I also didn’t notice any delay between video and audio when watching movies with this bluetooth headset. I’ve used these buds both stationary at my desk and while walking on my commute. In both instances, the sound quality remained good and the wireless speakers felt comfortable in my ear. Also, even for low tech people, the buds were super easy to pair with my phone and other devices.
These earbuds have a cool feature that allows you to control your audio using special touch gestures. By touching the bud itself, and not the phone, you can pause, play, and skip your music. I am still learning these gestures but I already appreciate having full control without needing a separate device.
Aside from the sound experience, one feature I would have liked to see on these earbuds is a smarter case. I appreciate the USB-C charging and the sleek, compact design of this product. However, it would have also been helpful to know the percentage of charge on the case itself. The LED on the case simply indicates if the buds are fully charged or not.
Overall, the Nubia New Sound C1 Bluetooth Earbuds provide comfort, style, and a superb audio experience which makes them perfect for daily use.
iPhone user here. I’ve been using these for about 2 weeks now. Normally I use AirPods Pro’s but I lost the original case and bought a replacement, not from Apple, that has messed up after 2 months twice. I love Anker products so I figured I’d give these a try since they cost less than a replacement AirPods charger.
First impressions were that it’s kind of a bulky case and it’s hard opening with one hand. Just a slight inconvenience. The fitting is pretty good. I’ve worn these for hours without much discomfort. My ears get sweaty so they slip out a bit but I just push them in a bit and I’m good to go. ( heres a tip: download soundcore app and set both ear controls for one tap to “nothing”. Helps avoid accidentally activating a function if you’re just adjusting your earbuds)
