Helen
Thanks, I’ll try the long press mode to save battery. But no, it is not normal to drain the battery in a short time in standby mode, at leas not as fast as it’s doing now. And one should be able to completely shut down even via remote control(on screen menu.
Maybe in a future OS update it will be available 🙂
I’d like to be able to solve the issue, but is contacting the support leading to some solution?
Thanks
davide
