Dreame MOVA 30 Ultra: A Powerful, Affordable Robot with Premium FeaturesReviews
The Dreame MOVA 30 Ultra is an exciting new entry in the world of robot vacuums. Although MOVA is a relatively new brand, it’s “powered by Dreame,” indicating a close connection between the two, though the exact nature of this partnership remains unclear. The MOVA 30 Ultra is a great example of their intention to offer innovative, high-performance robot vacuums at a competitive price. Priced around €500, it provides an excellent balance of functionality and affordability, making it a strong contender in its category.
🔹 Unboxing and First Impressions
Opening the box reveals the same premium experience that Dreame is known for. The MOVA 30 Ultra is well-packaged, with the robot, dock, side brush, and two mop pads neatly secured. While the dock is similar to previous Dreame models, it lacks a detergent tank, meaning you’ll need to add detergent directly to the water tank for cleaning.
🔹 Suction Power & Cleaning Efficiency
The MOVA 30 Ultra boasts an impressive 7,000 Pa suction power, making it effective at picking up dirt, pet hair, and dust from a variety of floor surfaces. It also features an ultrasonic carpet sensor, which detects carpets and automatically lifts the mop to prevent it from getting wet.
🔹 ProScrub Technology
One of the standout features of the MOVA 30 Ultra is its ProScrub technology. This rotating mechanism mimics a scrubbing motion, ensuring a deep clean, especially on hard floors. The system helps remove dirt and stains effectively, which is great for homes with high-traffic areas.
🔹 Design and Accessibility
With a height of just 9.7 cm and a width of 35 cm, the MOVA 30 Ultra is compact enough to fit under furniture like toilets and couches. The mops can be lifted up to 10.5 cm, making it versatile and effective on both hard floors and carpets.
🔹 Battery Life and Charging
The robot is powered by a 5,200 mAh battery, providing up to 260 minutes of runtime on a single charge. This long battery life makes it ideal for larger homes, and the fast-charging feature minimizes downtime between cleaning sessions.
🔹The MOVA E30 Ultra is equipped with a camera specifically designed for object recognition, which helps the robot navigate and avoid obstacles effectively. Unlike some other models, this camera is not intended for remote home monitoring, speaking through the device, or recording. Its sole purpose is to enhance cleaning accuracy and avoid objects in its path. This design keeps the focus on cleaning efficiency without additional features that would involve home security or monitoring capabilities.
🔹 Cleaning Modes and App Control
The MOVA 30 Ultra offers multiple cleaning modes, including Clean Genius Mode and Custom Mode. The app, Movahome, provides the usual features, such as setting cleaning schedules and defining the cleaning area. While the app’s settings are somewhat simplified, they feel optimized for this specific robot. It’s easy to use, and you can control cleaning times and preferences remotely.
🔹 Maintenance and Compatibility
The 3.2-liter dust bag in the dock allows for up to 75 days of hands-free maintenance. Additionally, many parts from the Dreame L40 Ultra, such as the Tricut brush and mop pads, are compatible with the MOVA 30 Ultra, offering great convenience for users who already own Dreame products.
🔹 Limitations
One drawback is that the MOVA 30 Ultra cannot store the mop pads in the base station, which might be an inconvenience for some users. However, this is a minor issue given the robot’s overall performance and value.
🔹 Conclusion:
The Dreame MOVA 30 Ultra is an excellent choice for anyone seeking a high-performance robot vacuum at an affordable price point. With its strong suction power, ProScrub technology, and long battery life, it delivers a thorough cleaning experience for various types of flooring. While it is a solid contender in the robot vacuum market, like any product, it comes with a few limitations. Here’s a quick look at the pros and cons:
Pros:
Strong suction power: 7,000 Pa suction capacity, effective for picking up dirt, pet hair, and dust.
ProScrub technology: Rotating scrubbing action for enhanced dirt removal, especially on hard floors.
Compact design: At just 9.7 cm high and 35 cm wide, it fits under most furniture, making it easy to clean those hard-to-reach areas.
Long battery life: 260 minutes of runtime, ideal for large homes.
App control (Movahome app): Easy-to-use app for scheduling cleaning times and managing cleaning areas.
Compatibility with Dreame accessories: The Tricut brush, mop pads, and other parts are interchangeable with Dreame models, making it convenient for existing users.
Hands-free maintenance: 3.2-liter dust bag that can last up to 75 days before needing to be emptied.
Cons:
No detergent tank: Users must manually add detergent to the water tank, which can be less convenient compared to models with an integrated detergent system.
No storage for mop pads in the base station: This could be a downside for users who prefer having everything stored neatly in the dock.
Simplified app settings: While functional, the app’s settings are somewhat stripped down compared to other premium models, which may feel limiting for users who want more customization.
Overall, the MOVA 30 Ultra is a powerful and affordable robot vacuum with great cleaning capabilities. While it has a few drawbacks, they are relatively minor considering its price and performance. If you’re looking for a versatile and reliable robot vacuum cleaner with mopping capabilities, the MOVA 30 Ultra is definitely a strong option to consider
If you’d like to support my work, I’ll include a link below. I’ll also provide a link to the Dreame Robots Global Facebook group where you can join for more insights, tips, and support on Dreame products.
https://facebook.com/groups/5344873285624653/
Mova E30 Ultra!
https://amzn.to/4fpE5g4
https://amzn.to/4fLPBSH
