Ivyisme
The other day you asked in the post, what specs and price would I put? 🌟🎥
Here it is after thinking and researching what I would like and thought was the best.
Image Quality that Mesmerizes 🎥✨
° Resolution: Native 4K (3840 × 2160) with support for 8K scaling, because we have to be ready for the future.
° Brightness: 3,500 ANSI lumens, ideal for any environment, whether it’s a movie night or a bright afternoon.
° Contrast: Stunning 2,000,000:1 dynamic for those deep blacks and colors that jump out at you.
° Display Technology: Laser or pure RGB LED, which guarantees true colors and a lifespan of 30,000 hours (forget about replacing lamps).
° HDR: Compatible with HDR10+ and Dolby Vision for a cinema-worthy viewing experience.
Premium Portability 🚀
- Compact Size: Fits in your backpack and still leaves room for your other gadgets.
- Weight: Just 1.5 kg, as light as a laptop.
- Design: Minimalist, with brushed aluminum and vegan leather finishes, because style matters.
Smart Features You’ll Fall in Love With 🤖
- Operating System: Android TV 13, full access to Google Play and automatic updates.
- Virtual Assistants: Compatible with Alexa, Google Assistant and Siri, because you never know which one understands you best.
- Auto-Focus and Keystone:Automatic correction in real time so you always have the perfect image without lifting a finger.
- Universal Casting: Compatible with AirPlay, Chromecast and Miracast, so you can project what you want from any device.
Connectivity for Everything 🔌
- Inputs: 2x HDMI 2.1, USB-C with DisplayPort, 2x USB-A, Ethernet, so you can connect EVERYTHING.
- Wireless: Wi-Fi 6E and Bluetooth 5.3 for seamless streaming and syncing.
- Audio: Optical output, 3.5mm jack and HDMI eARC compatibility.
Sound that Resonates 🎵
° Built-in Speakers: 2× 10W Harman Kardon, with support for Dolby Atmos, that fill the room without the need for sound bars.
° Optional: Sync with your external sound system via Bluetooth or HDMI eARC.
Screen and Projection Size 📐
- Projection Distance: Ultra Short Throw, projects 100” from just 30 cm.
- Screen Size: From 50” to 200” with dynamic adjustment, so you can transform any wall into a cinema.
Battery and Efficiency 🌱🔋
- Built-in Battery (Optional): Up to 3 hours of playback in maximum mode, ideal for outdoors or places without power outlets.
- Energy Efficiency: Eco modes to save energy and care for the environment.
$ Price 💸
I think a device like this should cost between $1,299 and $1,499 USD for all the specifications, but it would be a success if we get it on sale for less than $1,000.
To all of you who made it this far, I would love to know what you would add or if these specifications meet your expectations. 😄
