Recently, open-ear headphones have become a trend, with even Apple set to launch the PowerBeats Pro 2 this month. Huawei has also introduced its FreeArc Open-Ear Headphones to overseas markets. These headphones feature an innovative design using “Ni-Ti shape memory alloy,” which adapts to various ear shapes for a comfortable fit.
With an IP57 water and splash resistance rating, they are built to withstand different environments. Additionally, the FreeArc headphones offer directional audio transmission and noise-cancelling capabilities during calls.
Equipped with a 17×12mm dynamic driver, they deliver high-quality audio, and when paired with the charging case, the battery life extends up to 28 hours.
Stay tuned for more updates on the availability of these headphones in your region. Also, should we consider nominating this product for a tryout to launch an overall open-ear headphone tryout?
How do you compare the FreeArc headphones with Oladance, Apple, and Shokz? Which one do you think stands out as the best option?
