The speaker is very pretty, compact, came in black color.
Very good high-quality sound with bass, easy to use, the instructions are very colorful, everything is clear in it.
I found an Android app to use with the speaker (IOS app is available too), that allows use of equalizer and other useful things. Overall, I really like the speaker.
The package includes:
1. JBL GO 4 speaker
2. USB-A to USB-C cable
3. Instructions
4. Warranty
Thank you, Heyup. (I wanted to add another video, but unfortunately it won’t load.)
    Yamilion
    Nice presentation but also you need to add more info about the speaker, I understand that there’s no many aspects to write but you could try to tell us the battery duration, the comparison of other speakers, etc.
    Yamilion thanks for sharing 😉👍 I added you the tags tryout and jbl. Send the video in new comment here , and you could explain a little more the function of the speaker etc…
    Menguelez changed the title to REVIEW JBL GO4 .
    Yamilion You can add the videos with 10MB , just cut the video for sharing. That would be uploaded
    I just like the JBL GO 4. It’s a beautiful, lightweight, and compact speaker that works incredibly well for its size. This is exactly the kind of device that can be put in a pocket, backpack, bag, or placed literally anywhere at home or outdoors.
    I also liked that it is not afraid of water, the Go 4 runs for 7 hours on a single charge and charges in 3 hours. I didn’t have any other Bluetooth speakers besides this one, so there’s nothing to compare it with.
    From my point of view, it’s wonderful how the company managed to fit a much larger sound system into something so small that it’s not devoid of pleasant details that don’t even noticeably show up when highly aroused.
    All the edges are rounded, which looks very impressive. The front is decorated with the distinctive “JBL” logo
    and there are anti-slip and anti-vibration stripes on the back.
    The playback and volume buttons at the top are recessed into a protective block that extends over the strap to the GO 4 label and down to the USB-C on the right. In the opposite direction, the manufacturer chose an essentially identical solution on the side running through the entire lower part with hatching and four protrusions acting as legs, but with the difference that on the left he integrated a power switch, a Bluetooth pairing button and below other available functions of Auracast technology, under which there is a diode indicating the charge level.
    The device, which fits in the palm of your hand, is able to provide an unprecedented pleasant experience that can be enjoyed anywhere.
      Yamilion yeah that is the point! Well done and thanks for add more info and video💪
      Muchas gracias por la nueva información, quedó muy bien, sigue así ✨😉 Una cosa que note es que dura mucho para cargar jaja pero bueno .
      I liked your review because more than technical specifications, you gave a personal point of real use and that is also something that is sought here in the community, thanks for this point, quick, summarized but precise, by the way excellent video!!
      17 days later
      Yamilion nice review, It’s quite good as an introduction, but I’d like to know more about your experience using the equipment.
      Yamilion se escucha bastante bien es un buen gadget para escuchar la música 🎼 con ese sonido 👍🏻🫠
