Premium Performance at an Affordable Price
First of all, a brief introduction: although Mova is an independent brand, it is part of the same ecosystem as Dreame. Only recently has Mova decided to separate and operate as an independent brand.
The Mova E30 Ultra stands out as one of the most affordable and complete options in the world of robot vacuums and mops, offering advanced features usually reserved for high-end models but at a much more accessible price.
Its resemblance to some Dreame models is immediately noticeable, as it inherits their know-how. And thanks to a few small compromises, it still manages to offer a well-rounded product without compromising on quality or functionality. Everything, from the jingle the robot plays when turning on, to the voice that provides operational information, to the app design, will feel familiar to those who have used a Dreame robot before. And this is not a flaw, on the contrary.
Disclaimer: At NonSoloRobot™️, we received the device for free, with no compensation or obligation. My review is impartial and independent: the goal is to provide a comprehensive overview of the product, based on an objective analysis. I will only share my personal preferences when necessary and they should be taken as such., highlighting what I consider to be the strengths and areas for improvement to help you make an informed decision that suits your needs.
Unboxing
Upon opening the package, the Mova E30 Ultra impresses with its attention to detail and build quality. The E30 Ultra closely resembles the L40 Ultra. The box contains:
The power cable and user manuals
Everything is well-protected and ready to use.
Base Design and Features
The Mova E30 Ultra offers a compact and efficient design. The automatic base, measuring 340 × 456 × 590 mm, integrates all the main functions of autonomous robots in this category: charging, automatic dust emptying, and mop self-cleaning. This system, combined with the clean and dirty water tank capacities (4.5L and 4L, respectively), allows for longer cleaning sessions without the need to constantly refill or empty the containers.
Opening the 3.2L dust bag compartment, you’ll notice the first cost-saving compromise: despite the dedicated space, there is no detergent tank. However, this is not a major issue, as you can manually add a few drops of detergent when filling the water tank. (For tech enthusiasts, note that you cannot use this feature by adding a separate tank since the internal mechanism and corresponding app function are missing.)
In terms of cleaning and maintenance, the robot is easy to manage, requiring user intervention only every 10-15 days, depending on usage frequency.
Note: Silver ion disinfection modules compatible with Dreame models can be used. Although they are not officially distributed in Italy, they are easily found online.
Performance and Features
With dimensions of 349 × 349 × 98 mm and a suction power of up to 7,000 Pa thanks to the Vortex™️ motor, the Mova E30 Ultra performs excellently on hard floors and carpets, effectively removing dust, pet hair, and debris.
A key strength is its compatibility with the Tricut anti-tangle brush, ideal for pet owners. Thanks to its ability to cut hair and fur, it reduces maintenance needs and prevents clogging. However, this brush is sold separately on the official website or online stores.
Floor mopping is done via rotating mops, which help remove dust and fresh stains. Although the robot lacks an internal water tank, adjusting the return time to the base for rinsing achieves more than satisfactory results, comparable to robots with an internal tank.
An interesting feature is CleanGenius™️, which automatically adjusts settings and cleaning strategies based on floor conditions and usage habits.
The robot does not have an extendable mop (which was expected, given the price), but it compensates with the RoboSwing™️ function, which uses slight rear movements to allow the mops to reach edges. This solution is effective but takes longer to clean, as the robot momentarily stops each time it activates the rotation.
Note: Although not officially declared, the base, having the same dimensions as the X40/L40 models, is compatible with the Dreame self-cleaning mop plate.
Navigation and Sensors
The Mova E30 Ultra uses the LIDAR SmartPathfinder™️ navigation system, which maps the environment precisely, ensuring navigation comparable to top-tier models.
On the bottom of the robot, in addition to standard anti-fall sensors, there is an ultrasonic sensor for carpet detection. When the robot detects a carpet, it lifts the mops by 10.5 mm and increases suction power, preventing the surface from getting wet. The front camera and laser sensors further enhance obstacle avoidance capabilities.
Unlike higher-end models, the Mova E30 Ultra does not offer video surveillance or video calling functions, which remain exclusive to premium models like the P50 Pro Ultra.
Battery and Autonomy
The 5,200 mAh battery offers a declared runtime of 120-150 minutes, depending on settings and surfaces, allowing the robot to clean fairly large areas without needing to recharge. Additionally, the robot autonomously returns to the base, recharges as needed, and resumes cleaning from where it left off. Fast charging reduces waiting times, making the device suitable for large surfaces without excessive downtime.
App and Smart Controls
The dedicated app is stable, intuitive, and well-translated into Italian. It allows users to customize cleaning for each room, schedule cleaning sessions, and monitor progress in real time.
It features excellent options for creating shortcuts for more complex or frequent cleanings, a Do Not Disturb mode, mop washing and dust-emptying management, cleaning history visualization, and more.
The map can be viewed in 2D or 3D and fully customized, allowing users to separate rooms, rename them, set no-go and no-mop zones, place virtual walls, add furniture, and define floor direction (which helps improve mopping by guiding the robot along grout lines or wood grain).
Up to four maps can be saved by enabling the multi-floor function. The robot can be carried to any mapped floor for vacuuming, but for mopping, the base must also be moved and set up before mapping a new area.
You can adjust the return time for mop rinsing and drying time (cold air drying can be set from 2 to 12 hours; I found 6 hours to be a good balance).
If you have used a Dreame robot before, you will find the MovaHome app very familiar.
Moreover, thanks to compatibility with Alexa, Siri, and Google Assistant, the robot can be controlled via voice commands, simplifying the user experience. Currently, the voice functions are quite basic, allowing only start and stop commands. I was unable to assign specific room cleanings via Google Assistant.
Conclusion: An Unbeatable Offer in Its Segment
The Mova E30 Ultra is a robot vacuum and mop that offers premium performance at a competitive price. Thanks to its excellent suction and mopping performance, minimal maintenance requirements, and outstanding navigation, it stands out as one of the best choices for those seeking a complete and efficient robot without overspending, don’t forget that Mova provides a full 3-year warranty on all its products.
Personal recommendation: At list price of 499€ if you have a multi-floor home and want to buy two robots (one per floor) while staying under €1,000, this is an excellent solution that I highly recommend especially if you find it on sale.
Amazon affiliated link
Product page
Mova Community Italia
NonSoloRobot™️community & socials
