Perfect for sports, workouts and outdoor activities.
The MiiBUDS PLAY are comfortable wireless (TWS) in-ear headphones with hybrid active noise cancellation (ANC), which are in an elegant matte black, they have a long battery life and support fast charging.
They are designed to be super comfortable and not fall out of your ears when you move. MiiBUDS PLAY are suitable for everyday use, with sweatproof and waterproof IPX5 certification and state-of-the-art audio performance as well as a pocket-sized mini charging case.
MiiBUDS PLAY are an excellent choice for sports and outdoor activities.
The MiiBUDS PLAY headphones have integrated Hybrid ANC (Active Noise Cancellation) for your perfect sound experience.
Background noise is reduced and the sound and music experience is improved. MiiBUDS PLAY also have an integrated Ambience Mode function, which, unlike ANC, amplifies external noises and impressions when you need to be more attentive, for example in traffic. Therefore, these headphones are recommended as a versatile “4-in-1 product” for activities such as sports, relaxation, travel and work. Both earphones have touch control buttons to operate the headphones. Here you can easily change the volume, change songs, answer calls or turn the ANC and ambient mode on and off
