Top-level technology: Mova reinvents home cleaning
The Mova V50 Ultra Complete is the first premium range vacuum and floor-washing robot from MOVA, a new company that proves it offers innovative solutions for home cleaning.
In this review, we will analyze in detail all the features of this model, from technical specifications to performance on various surfaces, with a particular focus on the new technologies adopted. “Complete” refers to the inclusion of an extra set of accessories that covers approximately one year of usage. In the review below, we’ll explain what it includes.
It will be a long and in-depth technical review, but we are certain it will satisfy all your doubts or curiosities, so make yourselves comfortable!
Disclaimer: At NonSoloRobot™️ we received the device free of charge, without any compensation or obligation.
My review is impartial and independent: the goal is to offer a complete overview of the product, based on an objective analysis.
I will share my personal preferences only where necessary, highlighting what I believe are the strengths and the aspects that could be improved, to help you make a conscious decision aligned with your needs.
https://heyup-forum.s3.eu-central-1.amazonaws.com/2025-04-30/1746018799-563367-immagine-whatsapp-2025-04-26-ore-185339-66c5a61b.jp
Technical specifications
Below is a list of the main technical specifications of the Mova V50 Ultra Complete, highlighting the hardware and equipment that make this robot, at least on paper, the best currently on the market:
Suction power: up to 24,000 Pa (high-speed brushless TurboForce7 motor).
Main brush: double anti-tangle rubber roller TurboWave™ DuoBrush, designed to eliminate hair/fur accumulation and increase cleaning effectiveness.
This double eccentric counter-rotating brush helps remove 100% of tangled hair without jamming.
Side brush: 1 extendable side brush on command, which extends to reach corners, wall edges, and narrow areas, improving coverage without leaving “dead spots.”
A complete novelty, it is capable of lifting itself during washing or to avoid lifting the edges of carpets (FlexBrush™ Technology).
Mapping system: LiDAR DToF sensor (laser) mounted on a retractable turret (FlexiRise system).
The laser rotates 360° to precisely map the house, plus the turret can automatically lower itself when necessary, reducing the robot’s height to just 89.5 mm to pass under low furniture.
Obstacle sensors and object recognition: double technology (AI camera + 3D structured light) capable of identifying up to 200 types of objects and obstacles.
This allows the robot to avoid obstacles such as shoes, toys, electric cables, and even recognize and avoid pets’ “accidents” on the floor (preventing unpleasant incidents).
Obstacle overcoming: thanks to the StepMaster™ system, the V50 Ultra can climb thresholds and level differences up to 6 cm high, a great plus considering that most traditional robots stop at about 2 cm.
The additional motorized wheels extend to lift the frame, allowing it to overcome, for example, double-step door tracks, small steps (up to 4+2 cm vertically), high carpets, and U-shaped chair bases without getting stuck.
Battery: 6,400 mAh lithium-ion, offering up to 220 minutes (3 hours and 40 minutes) of autonomy in standard mode.
In other words, it can cover very large areas (even over 300 m²) with a single charge, depending on the cleaning settings.
Charging: when the battery runs out, the robot automatically performs the Return & Resume (returns to the base, charges, and then resumes cleaning where it left off).
It supports fast charging up to 30% faster than previous models and integrates an energy-saving function to charge the robot during hours when energy costs less.
Dust tank (in the robot): 300 ml capacity.
The robot automatically empties the contents into the emptying base at the end of cleaning or when full.
Self-emptying and washing base performs multiple functions
Automatic dust emptying: vacuums the dirt from the robot into a 3.2 L bag in the base, sufficient for about 100 days of use without needing replacement.
Water tanks: the base contains a clean water tank of 4 L and a dirty water tank of 3.5 L.
The robot automatically draws clean, hot water for washing and discharges the dirty rinse water into the respective tank, allowing numerous washing sessions without manual intervention.
There is also a sensor that detects the level and turbidity of the water to better manage the cleaning cycles.
Integrated mop cleaning: the base washes the robot’s rotating mops with an automatic cycle: a washing panel with 20 nozzles (JetSpray Dryboard™) sprays water and scrubs the mops to remove dirt.
A central filter retains the removed debris and channels the dirty water to the tank, avoiding stagnation.
Hot water for washing: the system is capable of heating the water up to 80°C for the mop washing cycle, improving effectiveness in removing stubborn dirt and sanitizing the cloths.
Automatic drying: after washing, the mops are dried with hot air at 60°C in 1 hour.
This occurs through the OmniDry™ system, which dries both the cloths and the washing plate, preventing the formation of mold and bad odors.
The dust bag also benefits from an airflow that prevents moisture (keeping the dust container dry).
UV sterilization: a UV-C lamp in the base performs sterilization, eliminating up to 99.99% of bacteria on the mops and 99.88% of bacteria in the dust bag after cleaning and drying.
This hygienic aspect is ideal for those with allergies or pets, ensuring that the robot does not reintroduce germs into the house.
Mop and floor washing system: two high-speed rotating round mops (up to 260 rpm).
The mops exert pressure on the floor thanks to the FlexiPress™ floating support (able to move ±2 mm and tilt 5° to adhere even on surfaces that are not perfectly flat), improving the ability to remove stains and also self-cleaning (the floating movement helps better wring the cloths during the automatic washing phase).
The two mops can lift by 10.5 mm when not needed or when the robot encounters carpets, thus avoiding wetting them.
Moreover, the right mop can extend laterally by a few centimeters (FlexMop™ RoboSwing technology) to clean near skirting boards and difficult spots, such as along walls or around the legs of furniture.
The system also allows the mop to protrude up to 4 cm beyond the robot’s edge thanks to a rotating movement to reach small spaces under furniture and appliances.
Washing with 50°C hot water: the V50 Ultra features the thermal washing function during floor cleaning, the robot is loaded with water heated to 50°C mixed with cleaning solution.
The use of lukewarm water helps better dissolve dirt (e.g., dry stains, grease) compared to cold water, improving the quality of washing without damaging delicate surfaces.
DuoSolution™ – dual detergent: another distinctive feature of this model, which has two separate tanks for liquid detergents.
This allows simultaneously loading a standard floor detergent (e.g., universal cleaner for robots) and a specific one for eliminating pet odors (thanks to N-Soya Morpholine, an agent that neutralizes odors).
Through the app, you can choose which solution to use during washing (e.g., use the odor-neutralizing detergent in rooms frequented by pets).
The robot automatically draws from the correct tank and mixes the detergent with the hot water.
Also filling the robot’s tank with the appropriate detergent.
This system is revolutionary for those who have pets at home because it allows switching from a “normal” cleaning to one targeted against bad odors.
Air filter and anti-allergen system: the robot integrates multi-layer HEPA filters to trap fine dust.
Moreover, there is a HEPA filter self-cleaning system: when the base performs the self-emptying, part of the airflow is redirected through the robot’s filter to remove the deposited dust, maintaining constant suction and preventing clogging.
This is a useful device for those who vacuum a lot of hair/fine dust, ensuring constant performance over time.
Noise level: no official data in dB is provided, but the manufacturer highlights the adoption of a low-noise design thanks to careful soundproofing work.
In practice, the V50 Ultra is quieter than other robots of similar power, thanks to vibration absorption systems and balanced rotation that reduce operating noises.
In Quiet mode (silent mode) the noise is discreet, while at maximum suction it can be audible but still attenuated compared to the average; during movements, practically almost no noise, not even from the wheels.
Dimensions: the robot has a diameter of 35 cm and a variable height of about 8.95 cm – 10 cm (retractable laser turret).
The base measures about 458 × 420 × 470 mm (W x D x H).
Aesthetically, the V50 Ultra is available in white color with a golden panel.
As you can see, the technical equipment is impressive: Mova has integrated practically all the best current technology into its V50 Ultra Complete.
In the following paragraphs, we will see how these specifications translate into real performance on different types of surfaces and in daily use.
Cleaning performance on different surfaces
One thing is the theory of specifications, another is practice.
We put the Mova V50 Ultra Complete to the test on various types of surfaces: parquet, stoneware/ceramic, and carpets, to evaluate its cleaning effectiveness in real scenarios.
On hard floors (parquet, stoneware, tiles)
On hard floors, the V50 Ultra excels in both vacuuming and washing.
The powerful 24 kPa suction ensures that dust, crumbs, hair, and debris are easily collected, even along skirting boards and in tile joints.
In particular, the combination of the extendable side brush and the double main rollers ensures that even dirt in corners and difficult points is effectively conveyed towards the suction mouth.
For coarser dirt (e.g., sand, kibble, dry soil fallen from plants), the robot manages to suck everything up on the first pass thanks to the strong vacuum created by the TurboForce7 motor.
Even heavy debris stuck between the joints of the tiles is extracted without problems if using the maximum suction setting.
The Particle Boost Mode automatically detects accumulations of large debris (thanks to the sensors) and temporarily increases the speed of the brushes and the suction power to capture everything.
When the washing mode is activated, the V50 Ultra tackles the floor with its two rotating mops.
But how does it wash the floors?
Definitely better than most competing robots with rotating mops: the 260 rpm mops with 8N of force exert a good mechanical scrubbing action, which combined with the 50°C hot water helps dissolve sticky stains and light encrustations (for example, sugary drink stains, dry mud brought by shoes, grease stains in the kitchen, coffee).
In tests on varnished parquet and porcelain stoneware, the Mova V50 Ultra removed dry coffee stains without leaving visible residues.
The hot water makes the difference on stubborn dirt: it takes less time to moisten and soften the dirt, so the mops manage to remove it in one or two passes.
It is important to underline that it does not leave streaks or excess water on the floor: the mops release the right amount of liquid (thanks to intelligent control and FlexiPress pressure balancing), and after the pass, the floor is just slightly damp, drying in a few minutes.
On parquet this is fundamental: in our tests, we did not find streaks nor any damage to the wood, a sign that the system manages the water dispensing well.
Furthermore, the robot automatically detects the degree of dirt on the floor: through its RGB camera and turbidity sensors, it identifies if there is a very dense stain (e.g., oil, sauce) and in that case, it can decide to pass multiple times over that area or return to the base to rinse the mops before continuing, avoiding dragging dirt into other areas.
Another remarkable aspect is the DuoSolution system for detergents.
In standard mode, we used a diluted multipurpose detergent provided with the robot, which does not release much fragrance but helps degrease.
In the dog’s room, instead, we selected via the app the odor-neutralizing detergent (loaded in the other tank): the robot automatically drew from that one, washing the floor with a specific solution to neutralize odors.
The result: after washing, practically no residual odor where usually the “wet dog smell” or litter box smell is perceived, and moreover, this specific detergent has a truly noticeable and very pleasant fragrance.
This confirms that the dual-detergent system is more than just a gimmick and brings real benefits for those who have pets.
On carpets and rugs
Carpets have traditionally been a tough challenge for floor-washing robots, but the Mova V50 Ultra also manages these surfaces in an ingenious and complete way.
Thanks to the ultrasonic sensor and advanced software, the robot automatically recognizes carpets: as soon as it detects one underneath, it immediately lifts the mops by 10.5 mm and stops them, to avoid wetting the fabric.
At the same time, it can activate the Carpet Boost mode, increasing the suction power to the maximum to extract dust and dirt from the carpet.
In our tests on a low-pile carpet, the change in noise could be heard when the robot increased the power over the carpet, indicating that the boost was active.
The V50 Ultra also offers carpet-specific settings via the app: you can choose whether to completely avoid certain rugs, or to detach the mops at the base for high-pile or delicate carpets, or to perform a deep carpet cleaning.
In this last case, we tried the option where the robot passes twice over the carpet at reduced speed for deeper cleaning.
The result was visibly better on a dense fiber carpet: after the slow double pass, it managed to extract even fine dust and sand that had not been captured on the first pass.
This “double suction” function is excellent for revitalizing carpets and is especially useful in homes with pets that shed hair or with entrance carpets subjected to stubborn dirt.
Another strong point is the management of hair and pet fur on carpets: the DuoBrush system with double rubber rollers proved not to get tangled in the carpet threads nor in long hairs.
At the end of the cleaning, inspecting the brush, we found no wrapped hair, a sign that the promise to minimize tangles is kept.
Moreover, the robot performs a sort of “compression” of the dirt in its dustbin: the two counter-rotating rollers tend to collect hair and lint and compress them into clumps, keeping the suction duct clear.
This ensures that the dustbin fills evenly without clogging prematurely, a useful detail for those who have a lot of hair to collect.
Note: for very high or thick carpets (shaggy, long pile), the V50 Ultra might physically not climb onto them even though the wheels have a considerable extension.
The 6 cm limit applies to rigid obstacles: on a very soft and thick carpet of 4–5 cm, the robot tends to treat it as an obstacle (it stops or avoids it unless the edges are tapered).
This behavior is actually preferable, because such carpets are hardly cleaned well by a robot.
In general, for normal carpets and fixed carpets up to medium pile, the Mova V50 Ultra provides excellent suction results, comparable to a good vacuum cleaner, but with the convenience of automation.
Floor Washing Quality (50°C and Dual Detergent)
Floor washing is one of the distinctive features of the Mova V50 Ultra Complete.
In this section, we focus on the washing quality offered by the robot, analyzing the key technologies: the use of 50°C water and the DuoSolution™ dual detergent system.
Washing with 50°C Water
Many floor-washing robots are limited to moistening a cloth with water without detergent and at room temperature, but the V50 Ultra takes the concept to the next level by heating the water and adding the appropriate detergent.
During operation in washing mode, the robot mixes the water from the internal tank with the hot water drawn from the base (which can be heated up to 80°C in the base itself), which should keep the mops constantly at about 50°C during cleaning.
What advantages does hot water bring?
Mainly a greater effectiveness in removing greasy and encrusted dirt.
In tests, light grease stains in the kitchen (for example oil splashes near the stove) that required several passes with cold water came off more easily with the V50 Ultra thanks to the action of the lukewarm water and detergent.
Even dry coffee stains on the floor were softened and cleaned better compared to washing with cold water.
Obviously, 50°C is not hot enough to damage surfaces or finishes: we can confirm that on parquet, laminates, and vinyl floors there are no problems, the temperature is moderate but effective.
An important point: during washing, the robot continuously monitors the state of the mops.
If the water gets too dirty or it detects that the cloths are saturated with dirt, the V50 automatically returns to the base to rinse the mops and renew the water, thanks to the multi-spectrum dirt detection system (color, turbidity, etc.).
We observed this behavior when it tackled a large area with many stains: halfway through the room the robot returned, cleaned the mops at the base (in about 2 minutes), and then resumed cleaning with clean cloths and clean water.
In practice, it works more similarly to a floor washer, rinsing the cloth when it becomes too dirty before continuing, instead of dragging dirty water throughout the house.
This ensures a high and uniform washing quality over large surfaces.
At the end of the washing, the base, as mentioned, carries out automatic drying: the mops come out clean and dry, ready for the next use.
Here, hot water also plays a role in hygiene: unlike other robots where the mops remain damp (risking bad odors), the V50 Ultra dries them with hot air at 60°C and sterilizes them with UV, leaving them fresh and germ-free.
After 12 hours from washing, smelling the mops, no smell of damp is perceived: a plus if the base is cleaned rarely (maybe once a week), since no mold will develop.
Dual Detergent System (DuoSolution)
The DuoSolution™ is probably the most peculiar innovation of this model.
What does it consist of?
As mentioned, there are two separate tanks for liquid detergents in the base: one intended for classic floor detergent and one for a specific pet detergent aimed at eliminating odors.
Mova provides both products in the package: a large bottle of universal detergent and a smaller one of anti-odor solution.
But in the main tank, any detergent can be used (as long as they are compatible and not excessively foaming).
Mova still recommends using only its multi-surface detergent, specifically designed for the robot.
During use, we found it extremely convenient to switch from one detergent to another without having to intervene manually.
Everything happens automatically: as soon as it enters the room designated as frequented by animals, the robot injects the other detergent into the water.
Management takes place via software: it is possible to label a room or area with a certain type of detergent, or manually choose “Pet” or “Standard” mode before starting a cleaning of the whole house.
In terms of effectiveness, the standard detergent cleaned well.
The pet detergent is truly effective in neutralizing odors: we tested it on a spot on the floor where the dog usually sleeps (and leaves a perceptible odor).
After cleaning with the pet solution, the wet dog smell disappeared, indicating that the odor molecules were attacked and neutralized, not simply covered with a scent, which anyway is really excellent.
It should be noted that the DuoSolution system never mixes the two detergents together: there is always a separate circuit, so there is no risk of contamination or creating strange cocktails.
Moreover, if one does not have animals, they could still load two different detergents, perhaps one scented and one neutral, or two different fragrances to alternate them (this aspect has not yet been tested and we do not recommend it yet until official indications from the company).
However, the greatest added value remains for those who have pets: it is truly a pet-friendly product, designed to manage typical problems (hair, dirt, odors) in a dedicated and automated way.
In conclusion, the floor washing quality of the Mova V50 Ultra Complete is excellent.
It may not reach the friction and effectiveness of self-cleaning roller robots or floor washers, but among rotating mop robots it is definitely one of the most effective in removing difficult stains.
Hot water and the adaptive mop system make the difference.
And the flexible detergent system adds that extra touch for hygiene and freshness.
Mapping technology, smart automations and app
The Mova V50 Ultra Complete is an extremely smart device, equipped with advanced navigation and mapping technologies, as well as numerous intelligent functions manageable through the app and with the integrated voice assistant.
Laser navigation and advanced AI
As already described in the specifications, the V50 Ultra uses a laser mapping system (LiDAR) through its DToF sensor placed in the upper turret.
This sensor quickly scans the environment at 360° and creates a detailed map of the house.
In the initial tests, the robot completed a 120 m² mapping in a few minutes, correctly outlining the walls, rooms, and largely even the main furniture.
The LiDAR precision is excellent: obstacles are avoided at the correct distance and the cleaning trajectories are optimized without random movements.
The peculiarity is the retractable FlexiRise turret: when the robot detects a low piece of furniture (like a sofa with little clearance underneath or a suspended nightstand), it can lower the turret by a few centimeters to reduce its height to 8.95 cm and slip under.
This feature is similar to what has recently been seen in a few other models (such as Roborock and Dreame) and is extremely useful for cleaning under beds, sofas, and low furniture where robots with a fixed turret often cannot reach.
We verified that the V50 Ultra was able to get under a bed with 9.5 cm of clearance, something impossible for almost any other LiDAR robot.
Once under the furniture, the robot continues to navigate using the camera; when it comes out, the turret automatically rises again.
In practice, no corner of the house is precluded, unless it is actually lower than 9 cm.
We noticed that during these phases with the turret lowered, navigation is not as precise and uniform, an aspect that surely could be improved in future updates.
In addition to the LiDAR, there is the front RGB camera with LED illumination for AI.
This module allows the robot to recognize specific objects: according to the company, it supports up to 200 types of recognized objects.
In our tests, we noticed that the V50 Ultra carefully avoided small obstacles such as slippers, charger cables left on the floor, socks, and even cat toys.
It did so by gently maneuvering around them, without pushing them around.
This indicates an excellent obstacle avoidance ability.
In particular, we deliberately placed a fake poop (made of rubber) on the carpet to simulate the dreaded “incident”: the robot recognized it and flagged it as an obstacle, avoiding it completely.
This “poop avoidance” function became famous with other brands, and it is reassuring to have it here too, especially for those with untrained puppies — although watch out for liquid poop, you have been warned!
The camera also serves for the surveillance function: through the app, it is possible to access the live view of the robot’s camera, to monitor the house or pets remotely.
You can even talk through the robot (it has a speaker) to get a pet’s attention or discourage certain behaviors.
The “Pet Monitoring” function also allows you to set a routine where the robot, when not cleaning, can patrol the house and send notifications if it sees movements (acting like a sort of mobile surveillance camera).
A fun feature is the Pet Virtual Play & Vlog mode: the robot can be manually driven to follow your pet and record a video clip from the app, creating “vlogs” from the robot’s point of view starring your pet.
It is mostly a playful function, but it shows the level of smart integration in the app.
App and smart control
The MovaHome control app is packed with options.
Once mapping is completed, it allows all the expected customizations and more:
Multi-level map management:
You can save multiple maps (e.g., ground floor, first floor, etc.) and the robot automatically recognizes where it is (if manually transported to another floor, thanks to the sensors).
On each map you can rename rooms, merge/split areas, draw custom cleaning zones.
No-go zones and virtual walls:
It is very easy to draw no-go zones (areas not to clean/cross) or virtual barriers from the app.
For example, we delimited the area of the dog’s shiny steel bowls with a no-go zone to prevent the robot from bumping into them while cleaning around.
You can also specify “no-mop” zones (where it can vacuum but not wash).
Selective and scheduled cleaning:
You can plan very detailed cleaning programs: for example, have the kitchen cleaned every evening after dinner, or vacuum the entrance in the morning.
It is possible to choose which rooms to clean and in what order, how many passes to perform, the suction power, and the level of water/mop pressure for each room.
Flexibility is at maximum, and thanks to the excellent automatic function CleanGenius™️ you can even forget about settings as the robot’s AI will manage them autonomously.
Carpet customization:
As mentioned, you can adjust carpet modes: avoid, lift mops and vacuum, increase suction, double pass, or even detach the mops.
Smart notifications:
The app notifies when attention is needed: e.g., “Low clean water tank”, “Check the dust bag”, “Self-cleaning cycle completed, empty dirty water within X days”, etc.
There is also monitoring of the consumables’ status (brushes, filters, mops) with suggestions on when to clean or replace them.
Manual and visual control:
As mentioned, it is possible to manually drive the robot through the live camera view, even activating the microphone to talk remotely.
It is certainly not the main function, but it is useful for inspecting the house remotely or entertaining guests by showing the “little robot” remotely controlled.
The app is much broader and proved stable and intuitive in our tests on Android; the Italian translation is good (there are just a couple of slightly clumsy translations, but nothing problematic).
Integration with voice assistants
In addition to the app, the Mova V50 Ultra Complete offers voice control both integrated and through external ecosystems.
In particular:
Integrated voice assistant “Hey Mova”:
The robot has onboard microphones and native voice recognition.
By saying “Hey Mova” near the robot, it activates and awaits a command.
You can give commands like “start cleaning”, “clean the living room”, “go to base”, “increase suction”, etc., all without needing Alexa/Google and without using a smartphone.
In our tests, recognition worked quite well in a quiet environment, while with TV on or background noise you need to speak a little louder.
It’s a convenient function if you want to start the robot immediately without searching for your phone.
Smart integration, Matter, Alexa, Google Assistant and Siri:
The robot is compatible with the main assistants.
For example, you can add it to Alexa and create commands like “Alexa, start the robot in the kitchen” or include it in smart home routines (e.g., when leaving home, start cleaning).
With Google Assistant you can similarly give voice commands.
For Apple, since there is no HomeKit, use is available via Siri through configurable Shortcuts.
Note that with Alexa/Google the available commands are a bit more limited compared to the integrated assistant, but they still cover basic operations.
The V50 Ultra can also become an active part of a smart home: in addition to voice integrations, it supports the Matter protocol.
Battery life and charging times
The Mova V50 Ultra Complete is powered by a high-capacity 6,400 mAh lithium-ion battery.
According to official data, this battery translates into a maximum autonomy of about 220 minutes (3 hours and 40 minutes) in vacuum-only mode, set to minimum power and without mopping.
This is a remarkable value, exceeding 3 hours, placing this model at the top of its category in terms of autonomy.
Real-world autonomy
Of course, actual autonomy varies depending on the modes used.
In our tests, with vacuuming at medium power and standard washing simultaneously, the robot covered about 120 m² (an entire large apartment) in about 180 minutes, consuming about 80% of the battery.
If maximum power is used continuously, autonomy drops significantly: with turbo continuously activated, we measured about 80 minutes of operation before depleting the battery, still a good result considering the intensity of the work performed.
An interesting aspect is the intelligent battery management in CleanGenius mode: the robot tries to optimize consumption based on needs.
For example, when on an easy hard floor with little dirt, it slightly reduces the power to save energy; when it detects stubborn dirt or moves onto carpets, it increases power and therefore consumes more, but only for the necessary time.
This modulation ensures that cleaning is always completed as efficiently as possible.
Moreover, if during a scheduled cycle the battery drops below a safety threshold before completing all the rooms, the robot activates the “Recharge & Resume” protocol: it returns to the base to recharge just enough to finish the job, and then resumes.
In our tests, after about 2 hours of continuous cleaning (the app indicated the battery at about 20%), we deliberately added another task and the robot autonomously decided to recharge.
It stayed in charge until it reached about 80% and then restarted to complete the remaining rooms, finally returning to the base at around 15%.
Everything happens without manual intervention and the robot memorizes where it had left off to resume exactly from there.
Charging times
To fully recharge the battery from zero, the Mova V50 Ultra takes on average 3.5–4 hours on the base (this is the time we recorded).
However, the accelerated charging function should be highlighted: the manufacturer states that the robot can recharge up to 30% faster under optimal conditions.
In practice, we noticed that initially the charging current is higher and allows a good percentage to be recovered in a short time; then it slows down in the final phase to preserve the battery.
For example, in 2 hours of charging, it went from 20% to 80% (about 60% in 2h), while for the last 20% it took another full hour.
This behavior is common in many devices to optimize battery health.
A useful feature: you can enable the charging mode outside of peak energy hours, allowing the robot to charge very slowly during hours when energy costs more, maximizing the charge during nighttime hours or, if you have a photovoltaic system, during hours of maximum sunlight, thus minimizing consumption.
A detail that shows attention to particulars.
It is worth mentioning that the multifunctional base allows the robot to charge even while drying the mops.
Some older generation bases did not recharge the robot until mop drying was complete, extending reuse times; here, however, the processes are parallel: the robot dries the cloths while simultaneously recharging.
Thus, after a full cleaning+washing+drying cycle, the robot will be almost ready, with both a charged battery and dry mops.
In short, the battery life of the Mova V50 Ultra Complete is more than sufficient to cover large homes in a single pass.
And in extreme cases of very large houses, the resume-after-recharge function ensures total coverage anyway.
The charging times are excellent, with the addition of an initial boost that can be useful for quickly restarting the robot if multiple passes are needed in a day.
The average user will probably never notice a battery limitation if not at home, because the robot manages everything autonomously.
Ease of maintenance and daily management
One of the great advantages of the Mova V50 Ultra Complete is its reduced need for routine maintenance interventions, thanks to the base that automates many operations.
Let’s analyze which maintenance actions remain the user’s responsibility and how often they must be performed.
Dust emptying
Thanks to the auto-emptying system with a 3.2-liter bag, it is not necessary to manually empty the robot’s dust container after each cleaning.
The robot empties itself into the base at the end of each session (or as needed).
The 3.2 L bag can hold up to 100 days of dirt according to Mova, a figure that can vary depending on how dirty your home is.
In our case (home with pets), after about 3 weeks of daily use, the bag was perhaps 30% full, so we believe it can realistically last 2–3 months for a standard user before needing replacement.
The base notifies via the app when it might be time to check if the bag is full.
Moreover, as described, the base dries and sterilizes the bag at each emptying, so it does not emit bad odors even if left for a long time.
Water tank management
The Mova V50 Ultra Complete manages water automatically.
However, the user must periodically refill the clean water tank in the base and empty the dirty water tank.
The tanks are large (4 L and 3.5 L respectively) with a module inserted in the clean water tank that inhibits limescale formation.
In our experience, with about 120/130 m² washed daily, the 4 L clean water tank lasted about 2 days before running out, while the dirty water tank was about ¾ full.
Therefore, you must remember to perform this task based on usage frequency and the size of the area:
The app helps by sending notifications when the clean water tank is empty or reminding to empty the dirty water tank.
As for the DuoSolution detergents, they must naturally be refilled when they run out (the app notifies this too).
Detergent consumption depends on how much surface you clean and the frequency set.
Indicatively, the large 1000 mL bottle of standard detergent provided could last for many months of daily cleaning (only a few milliliters are dosed per cycle).
The small 200 mL anti-odor bottle will probably last less if used often, but again we are talking about several weeks or months of use.
Fortunately, purchasing more detergent will not be a problem, and you can also use other specific detergents for robots and floor cleaners (make sure they are high-quality, as they make a difference).
Mova obviously recommends its own, but they do not seem to have warranty issues if you use other compatible ones.
Base and mop cleaning
The base requires minimal attention.
The mop washing plate has a filter that traps solid dirt (lint, hair) scraped from the mops: this filter simply needs to be rinsed occasionally.
We found only a few hairs and some muddy dust: a quick sponge wipe and it was like new.
The presence of 20 jets and the well-designed flow ensures the plate stays fairly clean autonomously;
we didn’t see any incrustations or dirty corners, indicating that the self-cleaning works properly.
The rotating mops are attached with velcro to plastic discs: if they become too stained or worn out, they can be removed and washed by hand/in the washing machine (we recommend 40°C without fabric softener).
However, thanks to auto-washing and drying, manual washing is rarely needed.
Maybe once in a while (monthly?) you may want to give the pads a deep wash to keep them white and efficient.
Fortunately, 12 pads are provided in the box (2 mounted plus 10 spares), so you can replace them once worn out (each pad is circular, about 12 cm in diameter, similar to those of Dreame and other brands).
Brush maintenance
The anti-tangle brushes do an excellent job at preventing hair buildup.
During a couple of weeks of use, the main DuoBrush brush never got jammed:
its structure (two floating rollers rotating in opposite directions) ensures that hair and fur are easily conveyed into the suction mouth without getting tangled.
The side brush has a particular design with slightly spiraled arms that prevent hair wrapping;
in fact, we never had to clean it, no tangles were found.
The omni-wheel (front caster) is shaped to avoid wrapping hair and indeed remained clean.
You only need to pay attention to cleaning the robot’s dustbin occasionally:
although it empties automatically, moist dust can deposit on the edges and filter.
The robot itself partially cleans its filter with a reversed airflow, but we recommend extracting the HEPA filter once a month and shaking or vacuuming it to maintain maximum efficiency,
or washing it as per the manufacturer’s instructions and drying it well before reinserting it (something we at NonSoloRobot™️ generally advise against if the filter is made of paper material).
Supplied accessories and spare parts
The equipment of this Complete version is truly remarkable: included in the box are a 1L bottle of multi-surface detergent,
a 200ml bottle of anti-odor detergent for pets, 3 bags for the base,
a replacement double main brush, two side brushes, 3 HEPA filters for the robot, and 10 spare mops.
In short, an outstanding equipment that will allow you to use the robot daily for about 1 year without having to purchase spare parts (only detergents might be needed).
Software updates, maintenance, and warranty
A modern “maintenance” aspect is that the robot receives firmware updates via OTA (over the air).
During the test, we received an update that slightly improved obstacle recognition, fixed some minor bugs, and significantly improved AI functioning logic.
Updates are quite frequent, guided by the app, and require the robot to be charging.
We recommend applying them because they often bring improvements to features, AI, and bug fixes.
Summarizing maintenance:
check brushes and filter once a month; rinse the mop washing plate filter once a week (or two);
change the dust bag and detergents every 2–3 months.
For everything else, the Mova V50 Ultra requires very little daily commitment: it almost does everything by itself.
Just keep it supplied with water and enjoy a clean and fresh-smelling house.
Last but not least, Mova offers a full 3-year warranty on the V50 Ultra Complete, as on all its products,
which not only shows great confidence in the quality of their products but also great attention and support for the customer should any issues arise.
Conclusions
The Mova V50 Ultra Complete has proven to be an exceptionally complete and high-performing vacuum and mopping robot. Throughout this in-depth review, we have seen how Mova has integrated practically all the latest innovations available in the sector into the V50 Ultra Complete, and even a couple of cutting-edge innovations: from extremely high suction power to the revolutionary dual detergent system, thermal mopping at 50 degrees, UV sterilization, and intelligent navigation with retractable LiDAR, extendable legs, and AI camera.
Currently available in white only; the black version will be released in the coming months.
In conclusion, the Mova V50 Ultra Complete lives up to its promises: it offers impeccable cleaning, making it ideal for those who want a consistently clean and fragrant home (even with pets and kids) without daily manual effort.
It’s a true smart domestic ally.
Sure, there are always aspects that could be improved (e.g., the base could have a direct water refill from the plumbing system in the future), but these are minor issues overall.
At the time of writing this review, we can confidently say that the Mova V50 Ultra Complete is one of the most advanced and complete vacuum-mopping robots on the market, if not the most advanced overall.
If it fits your budget and you are looking for the best, we are sure it will not disappoint you.
Mova Community Italia
NonSoloRobot™️
AMAZON AFFILIATE LINK
PRODUCT PAGE
