The product is a Beta Test so this fact is absolutely to be considered.
The “boxe” is super easy to install, you get the HDMI cable inside the box and you only have to plug it in your TV to make the system appear on the screen.
The box runs on Android and it’s very intuitive.
You will have many games already installed on it and you will find them split in categories:
Arcade
GameBoy
GameBoy Advance
GameBoy Color
Nintendo 64
NES
PS1
PSP
SNES
You get 2 controllers that come without batteries (in the final version it could be cool to add them) and an infrared USB to plug in the box to make the controllers usable.
But let’s go to the gaming part: unfortunately I could not find a way to change the language of the games and that could be a problem since I don’t speak any kind of Asian languages so for the final version I suggest to put the roms inside the SD in the multilanguage version.
You can set the video quality output so you can range from standard definition to ultra quality, the one I chose since I got a 4K TV and, moreover, you can set the screen format.
Some games are lagging and MarioKart64 wasn’t usable since the framerate was so slow I couldn’t get to run the game.
Moreover, you also get a list of games that are not on the SD and you get the chance to play with other players on your server if you want so that it’s a pretty and cool function 😊
Let’s come to PROS and CONS!
PROS:
Very easy to install
Intuitive
European server available
Lots of games installed on it
Joysticks well made even if light
CONS:
Games only in one language
Lagging and low framerates in some games
For all the pros and cons written before I would give this product an overall score of 3.5 since the language barrier was a real struggle for me.
Hoping that the developers will keep my feedback in consideration �
