Freeirobot P10 Ultra: A Futuristic Robot Vacuum That Redefines Mid Range Cleaning
I was lucky enough to be a beta tester for the Freeirobot 3i P10 Ultra, and let me tell you, I’m genuinely impressed. This remarkably futuristic-looking robot, crafted by the rapidly growing Freeirobot, truly stands out with its innovative solutions. Specifically, we’re diving into the P10 Ultra, a model positioned in the mid-range but packed with features that challenge even high end devices.
First Impressione Design & The Intelligent Base
The P10 Ultra, also known as “Mr. Egg,” is more than just a cool looking robot. It’s made to be smart and fit well in your home. It can connect to both 2.4 GHz and 5 GHz Wi-Fi, so setup is quick and easy.
The base station has a modern gray color that looks nice in any room. It’s not too heavy, and there’s a handle and a cable port in the back, so you can move it without trouble.
On top of the base, there are two water tanks one for clean water and one for dirty water. This helps the robot keep your floors clean without needing your help all the time. There’s also a bright light that shows if the robot is working or needs something.
In the front of the base, there’s a dust bag that collects dirt and hair. Most people only need to change it every two months, but homes with pets might need to change it more often. The base also has a smart detergent system that adds cleaning liquid by itself using a special cartridge and you can already find refills on Amazon. Unfortunately i didn’t get one when the beta was started.
Overall, The 3i p10 ultra is made to make cleaning easy, smart, and hands-free.
Advanced Mop Cleaning & Maintenance
The P10 Ultra’s base station makes mop cleaning much better. It uses 60°C hot water and a special cleaning liquid from a cartridge to wash the mops well and quietly. Unlike older models, it doesn’t use a rubber scraper just hot water and active cleaning.
And here’s the best part when the robot goes back to the base, a built-in cutter turns on and cuts away hair stuck in the main brush. This means less work for you especially helpful if you have pets!
Meet Your New Cleaning Hero Smart, Strong, and Ready for Anything
The robot is 34 cm wide and 9.8 cm tall including the small tower on top. That size is pretty normal for robot cleaners.
It has a special camera in the front called Apex Vision. This camera uses smart AI to recognize over 100 different things on the floor. The robot uses this camera to move around and avoid objects. You can also use the camera to watch your home when you are not there.
On top of the robot there are three buttons. One sends it home, one turns it on and off, and one resets the Wi-Fi. Inside the robot is a large dustbin. It also has smart sensors that help it stay close to walls and avoid crashing into things.
This robot is very good at cleaning
The mops can move outwards to reach corners and along edges. Many other robots cannot do this
The mops spin very fast. They turn 220 times every minute. The robot can also see stains and work harder to clean them
It has very strong suction power with 18000 Pascals. This means it can pick up dust and dirt even from thick carpets
It knows when it is on a carpet. It increases suction and slows down to clean better. You can tell it to vacuum carpets first and then mop the hard floors after
The main brush is made with both bristles and rubber. It is made to stop hair from getting stuck. If the robot sees crumbs the front brush slows down so it does not push them away
If the room is dark the robot has a small light in front. This helps it see and clean even with the lights off
Intelligent Mapping & Customization via App
The app is very easy to use and is actually one of the best parts of the P10 Ultra. It creates a smart map of your home, showing rooms and furniture automatically. You can also change the map yourself if needed.
The P10 Ultra uses AI to watch your home and adjust the cleaning settings for the best results. It learns by itself, but you can still control everything. There are four suction levels and three mop washing levels, so you can choose what works best. You can also set up your own cleaning plans like a gentle mop for wood floors and a deep clean for marble.
Just one small thing to know if your floor has patterns or mosaic tiles, the robot might think the design is a stain. But don’t worry you can turn off this feature in the app if it causes problems.
A Few Things to Keep in Mind
The Freeirobot P10 Ultra has many great features, but there are a couple of things to keep in mind. It comes with a special tank for detergent, but if you want to use a different cleaning solution, you’ll need to pour it manually into the detergent cartridge.
Also, because of its LIDAR tower, the robot is 9.8 cm tall. This means it might not fit under very low furniture anything lower than 10 cm. So it’s a good idea to check the height of your furniture before buying.
The Freeirobot P10 Ultra really lives up to its nickname “The flagship killer "it’s small but full of smart features. It comes with advanced Apex Vision AI, super-fast mop rotation, an automatic hair cutting system, and a very easy to use app. Even though it doesn’t have a built-in detergent tank and might be too tall to fit under very low furniture, its smart design and strong performance make it a great choice for anyone who wants a powerful and mostly hands free cleaning robot.
