Let me start by saying that this was my very first smart watch of any kind. I was very excited to be chosen to test this watch and give my honest opinion. Here goes nothing.
I was really happy to see how easy it was to get my CMF(By Nothing) Watch Pro put together out of the box and how easy it was to find the the App and get started making this watch my own. I found it very easy to set up for someone who knows nothing about smart watches or how they work. The fact that I could choose my display to make this watch feel more like something I would choose for myself was great.
The fit of the watch was great, you hardly could even tell it was on your wrist because it is so lightweight. The ability to adjust the brightness, which I noticed helped save the battery power as well is great. Also this is the first watch I have seen that has a flashlight on it. I used it quite a bit. The ability to make the decision of if the the display stays on or just comes on when you raise you arm is an added bonus.
I was able to keep up with my daily steps, my daily heart rate, my daily oxygen levels. It is also nice to have a watch that keeps up with your stress levels. I is also nice to know what the weather is going to be like for the day. You also get your notifications on your watch, even though you can’t reply you still know you have them on your phone and they need tending to. You can even have it set to remind you to get up and move around if it senses you have been sitting for a while so you can be more active. You have everything you need at your fingertips on your watch face so you don’t have to use your phone as much.
As far as the calls go, the watch is linked to your phone via Bluetooth. The calls are clear and have a noise-canceling technology to help people hear you better and to help you hear them better.
The only problem I have had with my watch is the fact that it doesn’t want to stay connected to my Samsung A32 5G without the App being open in the background. I have to leave it open in the background or it will disconnect from my phone. I am sure there is a way to fix this.
In conclusion the CMF(By Nothing) Watch Pro I received to test and give my honest opinion on is a great Minimalist Watch for daily use. I would recommend the CMF(By Nothing) Watch Pro for anyone who is looking for a daily use watch that doesn’t cost a lot of money.
