Look/Presentation: The case is quite chunky and not very pocketable, but the case is chunky because of the big battery it holds.
Fit/Comfort: The buds come with S/M/L ear-tips with medium already installed out of the box. Quite comfortable fit when you find the right ear-tips, but not great for side sleepers.
Battery/Features: The earbuds themselves have 8 hours on a single charge and 140 hours with the case , meaning you only have to charge the case one a month!!!. The earbuds also have Bluetooth 5.3, which allows it to have multi-point connection and they are touch control.
App: These earbuds come with a companion app that allows you to get firmware updates, change touch controls, preset and custom EQ controls. You can also control the level of Anc and transparency through the app.
ANC: For $30 the ANC on these are pretty impressive as well as the transparency mode. I would say it blocks out about 80-85% of outside noise and the transparency sounds very natural and doesnโt have a robotic sound to it.
Sound: BASS HEADS REJOICE!!!! Very clear sound that leans more towards a bass heavy sound, but the sound can be changed to tone down the bass( or turn it up๐) in the app to suit your preferences.
