For those who live in the house, not just photograph it.
Roborock, the ones who transformed the world of robot vacuum cleaners, decided it was time to get serious also with cordless vacuum cleaners. Thus the H60 series is born, with in parallel the H60 Hub versions equipped with a self-emptying base.
This is not the usual vacuum cleaner “for the days when the robot doesn’t make it”: here the ambition is to make it do the main job. It is not the usual line of cordless stick vacuums thought for the quick little task: these are reliable products, designed with criteria to cover all needs, from those looking for a compact stick for small apartments, to those who need more pushed performance, up to those who, due to allergies, do not want to literally put their nose in the dust, avoiding direct contact with dirt and finding the stick vacuum always clean, charged and ready, with an advanced filtration system.
What they have in common
Foldable tube up to about 90° in the H60 series: to slip under low furniture without bending.Extendable telescopic tube in the H60 Hub series: to reach higher pointsGreen front light: illuminates the hidden dust, and once seen you can’t ignore it anymore.Very cared filtration: 5 stages + 9-cyclone system + HEPA, able to block 99.95% of particles up to 0.3 micron, TÜV Rheinland certifiedAnti-tangle brush for hard surfaces and carpets: designed to handle fur and hair that often scare cordless sticks.Transformable crevice tool with dusting brush.Good ergonomics: materials and assembly from mid-high range, not a toy.
What the Auto-Empty Dock adds in the Hub versions
The Hub versions (H60 Hub, Hub Pro, Hub Ultra) include a base that does two jobs:It automatically empties the dust collected by the stick into a sealed bag (2 L or 3 L depending on the variant).It simultaneously charges the stick vacuum when it is placed in the dock.In the Hub Pro and Ultra versions you can store the accessories hiding them in the base.
Practical use: how they behave in real life
On hard floor the H60 “slides” light like a racing bike, very light (~1.7–1.8 kg), they are handled easily also thanks to the good balance, they do not fatigue wrist and arm. The tube that bends allows you to reach under beds without kneeling like a restorer of the Uffizi, while the extendable tube of the Hub versions adapts to the height of every user.The green light shows you what you would NOT have wanted to see: no longer just “clean house”, but “oh my God look what lived under here”.On carpets and fur, the Pro/Ultra versions start to “chew dirt” seriously. They work well on short-pile carpets, more in difficulty on long-pile carpets where the conformation of the roller does not help to agitate the fibers to remove debris deeper down, but on all other surfaces it has the merit of not agitating you. You do not have to go over multiple times like with cheap sticks, here what it sucks, it takes away, without tangles on the brush thanks to the JawScraper Hybrid system.
It also has flaws
Real autonomy in “high power” modes drops very quickly.
No automatic mode that adjusts power by itself based on the amount of dirt: this feature besides being convenient could have helped in offering a better balance between power and autonomy, without having to intervene manually.
The self-emptying base of the Ultra Hub version is big: like a relative added by treachery in the house: you have to find it a dedicated place, it does not disappear by itself.
Edges and corners: excellent, but not magic. If you expect geometric miracles a priest can help.
Concrete differences between versions
H60
Small/medium house, hard floors
115 AW
~60 min
Crevice accessory, LED display, wall mounting bracket
H60 Pro
Medium house + carpets/animals
170 AW
~80 min
Mini motorized brush, crevice accessory, LED display, wall mounting bracket
H60 Ultra
Large house, intense use
210 AW
~90 min
Hub versions
Any range + extra convenience
Same AW as variant
Same autonomy as variant
Self-emptying dock (2 L bag hub version, 3 L bag hub pro and hub ultra versions)
Mini-guide to the choice
- Small house / only hard floors → H60
- Medium house + carpets/animal fur → H60 Pro
- Large house, thick carpets, animals → H60 Ultra
- You want maximum convenience (no manual emptying) → the Hub version of the tier you chose
Conclusion
The H60 series from Roborock is perfect for those who want real quality of use without too many frills and at affordable prices, it is not “an alternative”: it is a vacuum cleaner for those who clean for real and do it daily. If you have carpets, fur, people in the house, real life, you notice it immediately.The Hub version is the turning point for those who do not want to touch dust ever again. It costs more and occupies space, but it eliminates a gesture that everyone hates.All at accessible prices for the features offered, from 249 euros of the H60 to 499 euros of the top version H60 Hub Ultra.It is not a perfect product but a product that does the right thing: it cleans well, if you choose the right version based on house and habits, you will have a product that works, economical, light and that will make you want to use it.
If you want, feel free to follow my social communities NonSoloRobot™️ Enjoy a smarter life, everyone.
