Smartphones are evolving fast. New devices will feel smarter, more connected and more sustainable.
Key trends to watch
Smarter by default: Phones will use on-device artificial intelligence to learn your patterns, adjust settings, help you make choices.
Faster networks: The upcoming 6G technology promises ultra-high speeds and ultra-low latency—so streaming, gaming and AR/VR will improve significantly.
Flexible and full-screen design: Rollable, foldable or even transparent displays will become more common. Expect larger screens in smaller bodies.
Sustainability and repairability: More phones will use recycled materials, modular parts you can replace yourself and designs that reduce e-waste.
Better security and biometrics: Expect improved authentication methods (face, iris, voice or behaviour) and stronger encryption to protect your device and data.
Wider connectivity: Satellite links and global coverage will make phones usable in remote areas and during emergencies.
What this means for you
You’ll spend less time fiddling with settings because the phone will adapt automatically.
Upgrading might involve modular components instead of buying a full new phone each time.
Network quality and performance will matter more—so choose carriers and devices that support next-gen tech.
Your device will play a bigger role in your security and health; you’ll want features that protect you and your data.
Design and materials will influence your choice: eco-friendly phones will become appealing.
Final note
If you’re planning to upgrade or buy soon, aim for a model that supports AI features, good connectivity (5G/6G readiness), durable/repairable design and an eco-friendly build. These future-proof features will keep your device relevant longer.
