You thought robot vacuum innovation was done? Get ready for a surprise! Dreame is proving everyone wrong with their amazing new Matrix 10 Ultra.
The Next Generation of Mopping
The biggest news is that this robot can change its own mop pads right in the dock. You don’t have to touch a dirty one ever again! This is called the Multi-Mop system, and it’s a huge deal because it stops the same dirty water from being spread all over your house. The robot uses a different mop for different areas, which is really key to stopping germs from moving around the house.
You can set it up with specific mops,an absorbent one for the bathroom, a nylon one for the kitchen grease, and a standard one for your bedrooms.
https://heyup-forum.s3.eu-central-1.amazonaws.com/2025-10-27/1761597637-714241-img-20251027-212135.jp
Ultimate Floor Care The Triple Tank
This robot might be the best floor cleaner ever because its dock has three spots for different cleaning liquids. You can load it up with separate solutions: one for general cleaning, one for taking special care of your wood floors, and even one to fight pet odors. The robot figures out which cleaning liquid and which mop to use for each room. It’s truly a tailored clean for every surface
Power, Intelligence, and Ai that recongnize 240 different thing on the floor.
This robot isn’t just a gimmick, it’s a cleaning powerhouse. It has a massive 30,000 Pa suction that’s huge for a little robot! Its smart AI technology helps it see and dodge over 240 different things on your floor, like shoes or cords. If it sees a big mess, like that ketchup test in the video, it knows to go back and scrub the area many times until it’s perfectly clean.The design is smart, too. The robot can actually tuck its head in to become smaller, letting it slide under low furniture where dust usually hides. It also has dual, anti-tangle brushes and a side brush that pops out to sweep debris right out of corners.
The best part is that the mop system can tilt up to 10 degrees, which helps it stay closer to the floor and clean better, even on uneven surfaces.
Fully Automated Maintenance
The oversized base station handles all the dirty work for you. It washes the mops in scalding hot 100°C water to kill germs and then dries them to keep them fresh. Plus, it holds dirt in a big bag for up to 100 days!
This is more than just a vacuum, it’s an automated floor care expert. With the triple detergent tank and self swapping mops, Dreame has certainly raised the bar! The only thing that I don’t like is the big dock that can be difficult to fit in every house.
What do you think about the Matrix 10?
If you want to know more about the Dream products follow the Dreame Global Community on Facebook!
https://facebook.com/groups/5344873285624653/
