Video of the Benefits & Features.
I’m really loving this HeyPlus Watch, it has a ton of features and benefits. But first, I want to start off with the packaging. That really caught my attention. It comes in a nice box that says “Born To Brave”. Absolutely loved the saying, and the packaging! Onto the watch, the design is great! The watch face is the perfect size, making the screen easier to see. The band is very comfortable when wearing. It’s very light weight, I honestly forget that I even have it on most of the time. The battery life is fantastic!! It lasts up to 21 days, I’ve had it for about 3 or 4 days now and I’m still at 90 percent. That’s with it being on and used the entire time! Back to the screen, I really like how clear it is. You can just turn it like you’re checking the time, and the screen automatically comes on. The touchscreen is very easy to work and use. Next, when setting this up, it was a little difficult. It makes you scan a QR code before you can use it. That I didn’t care for, because sometimes the QR codes do not want to scan or work. Which is the issue I ran in to. While it did scan, it wouldn’t pull up the app, so I couldn’t get it to work. The app is set up for Apple products only. There is a link to download a APK file to use for android. However, I don’t care for that at all! I would like to see there be the same app for android users. But, once I got that figured out, I was able to get the code scanned and the watch working. Other than that, the set up process was very easy. I would like to see when choosing weight, it be in LBS, instead of CM. Same with height, as they can be confusing. But, I’d really like to see this work without having to scan a QR code first. Make it to where we can set it up, then scan the code. Also, include a app for android users, instead of downloading a file. Or, include the file somewhere in the paperwork where it’s easy to find. Next, some of the benefits that I like with this. One, you can monitor your heart rate and oxygen level. Two, this tells you how many steps you take. Three, sleep monitor, that monitors your sleep quality. Four, work out mode, that tells you heart rate, distance, calories, and steps. This also has work out records, that keeps track of all your work outs which is nice!! Five, this one is called Mindfulness, that helps you get calm and focus on your breathing. It’ll tell you to inhale for how long, and exhale for how long. Now onto some of the features that is super nice to have! This includes stop watch, timer, alarm, weather, and Wechat pay. All work very well, but I would like there to be an option to have a sound for the alarms. While the vibration does wake me up most of the time, having the sound would help too. The watch actually has no sound, which I’d like for it to have sound for certain things. Next, these features I absolutely love! I can use my watch and control my phone!! First, the music control, which allows me to play my songs from my phone. It also allows me to skip forward and backwards, plus control the sound volume. Second, the camera remote, I will say you will have to try and set this up for the camera to work. When I try using it, all it does is turn my volume up, haven’t figured out how to get the camera working yet. Another thing I’d like to see added is record. Where we can also choose to record or take pictures. Third, this one is my favorite! The find your phone setting. I have a horrible time at sitting my phone down and forgetting where I sit it at. This will take me right to it, and it’s pretty loud! Which makes it extremely easy to find, that I absolutely love!!! Makes life so much easier!! Lastly, you can customize the screen to different pictures, control the brightness, set reminders, place on do not disturb, and check the battery life. Overall, this is a terrific watch! There are so many different features and benefits that I really love with this one. There are a few cons that I’d like to see figured out. Plus some more different features added. But, honestly the pros outway the cons by far!! Some of the features I’d like to see added would be, checking email, having internet access to check social media messages, being able to download apps, etc. Phone calls, text messages, sound, being able to change the background to alot more than just what’s on the app. Plus, I’d like to see it allow more than 6 pictures to be saved for the display. I’d like to see that be unlimited. I would also like the instructions to come more detailed. Explaining how to use all the different features. Like the camera for example, how to get it set up and working. One last thing I want to mention, I accidently got this soaked, as I forgot I had it on when I got in the shower. It didn’t hurt it at all! So I’m loving that it’s waterproof as well. I would absolutely recommend!! It’s a great watch if you’re looking for something strictly for monitoring and working out. The overall quality is honestly terrific!!
