EdsonA Me gustaría probarlo para ver sus características y su calidad de este producto Ya que en muchas ocasiones hay reloj elevado por su precio pero que no dan buenas características como se espera
Doug I’m more of a visual learner and you just provided a bunch of pictures and it helped a lot thanks!!
NgannKoemchhuy Hey! the heyplus app does not work right now!!! Heyplus App Dev, Please kindly fix it. I can not activate my heyplus watch beause of app does not work.
Menguelez NgannKoemchhuy try to download the last version from here. If you have the last version installed then select an old version and check
Menguelez TeachTips_TT_ try to download the last version and check if not work try older versions : https://apkpure.com/es/heyplus/com.ryeex.groot
TeachTips_TT_ The web backend for this app properly drop down. For any solution, please kindly help me.
Menguelez TeachTips_TT_ if not works down page there are older ti try : https://www.pgyer.com/apk/apk/com.ryeex.groot
Menguelez NgannKoemchhuy try this : https://play.google.com/store/apps/details?id=com.crrepa.band.heyplusfit https://apps.apple.com/tr/app/heyplus-fit/id6473154498
NgannKoemchhuy Menguelez It can’t activate with heyplus watch model. My activation process stuck with QR scan to sync with smart phone.
