Daniking Below is my review of the product ‘ Heyup Boxe Lite Smart projector ’. I start by saying that the shipping was perfect both in terms of timing and packaging. The outer box is of good quality and I also appreciate the coloured holographic print on the cardboard which makes it unique. The quality of the outer plastic is very good, it has all the features to withstand shocks, the ease of use of the remote control is also good. Since it arrived I have kept it on every day to test the resistance of the LED lamp, using it for about 5 hours a day, maintaining a stable temperature between 50-60 degrees celsius, thanks to a fan placed on the side of the projector, which is not very noisy. I find the possibility of adjusting the viewing angle according to the type of mounting performed very useful. The internal sound of the device is quite sufficient, the quality of the low frequencies should be improved as when watching some action films it may not be perfect, but this is solved by connecting the projector via its Jack 3.5/AUX output via its external port to a home theatre or speaker. The sound is not very loud so if there is external noise it could cause discomfort, but as mentioned before this can be solved by connecting the projector to a home theatre or speaker The openness of the image following the positioning from the white cloth is very good, even enlarging the image by transforming into a “cinema effect” view as if it were a multi-inch TV, it does not grainy in fact, it remains clear and sharp. Overall, I can say that the strength of the projector is the excellent video quality transmitted even in the presence of light sources of varying intensity and brightness, However, viewing inside a darker room is recommended as the 150 Lumen ANSI, with too much light, may not show the screen sufficiently. The very light weight of the device allows it to be transported. IT HAS THE FOLLOWING OUTPUTS 1 HDMI 1 JACK 3.5/AUX 1 USB-A 2 infrared sensors ( forward and backward ) TESTS PERFORMED 2 hours on Youtube to watch content in 1080p without any problems 4 hours connected to a console to play in 1080p without any problems. FEATURES has 1gb of ram although it can watch content in 1080p without problems 4 cores. Possesses 2 video formats: 4:3 ( both always in 1080p.) 16:9 (both always in 1080p.) Allows you to adjust the viewing angle by up to 40 degrees per side to suit many surfaces The dimensions of 12cm x 14cm x 16cm and a weight of about 1KG make it very versatile and compact. Therefore, I highly recommend the purchase of this product.
