Hi there,
Here my youtube video about the Nothing Ear (a) Bluetooth Headphones
The Nothing Ear (a) bluetooth 5.3 headphones are in-ear wireless headphones equipped with 6 microphones, active noise reduction and IP54 certification.
In terms of autonomy, the brand announces up to 42 hours of use (with the charging of the case) and rapid recharging.
The Nothing Ear headphones (a) have a rather classic design and are available in three colors: black, white and black/yellow, everyone will choose according to their tastes.
Regarding waterproofing and dust resistance, they have IP54 certification (protection against rain and perspiration).
The connection with the smartphone or PC is simply done through the Bluetooth settings. They are also Google Fast Pair compatible for quick pairing with an Android smartphone and Microsoft Swift Pair with a Windows PC.
Wearing sensors are also present on these Nothing Ear headphones (a), this allows you to pause as soon as you remove the headphones.
Regarding sound, the Nothing Ear (a) feature dynamic transducers designed to increase low frequencies. They are also compatible with the most standard Bluetooth audio codecs on the market, AAC and SBC.
Note, the Nothing Ear (a) also have active noise reduction technology which is added to passive isolation.
The NOTHING X application will allow you to adjust the control and sound options for these Nothing Ear headphones (a).
