This is my first review, if you have doubts or questions you can ask me.
I have been using the device for almost a week to test it and I can say that it’s truly a good device.
Inside the box you will find
Talking about the screen:
It has an OLED 6,9″ and the external 1.43″, the refresh rate up to 120Hz and its resolution is 2790*1188. With this resolution you can watch videos with very good color and especially a better experience is made with its DTS sound. The only problem with the screen is with the external, if you’re outside sometimes it’s hard to see it.
It feels very fluid, but consumes more battery so I recommend to keep it in 90 Hz. This is also because the battery is 4310 mAh.
Talking about videogame performing:
Even if the device has a slightly old processor, it’s a good processor. It is a Sanapdragon 7 Gen 1, 2.4 GhHz. Most games can be played with medium to high graphics by default. It is quite fluid to play and the screen is large, to play you can have more field of vision in some games without losing resolution
Here you can see the example
I tried it with different games, but only with Cod Warzone I played with low graphics.
Even playing with a 4310 mAh battery, you can play for a long time. I played for an hour and lowered almost 20 percent with maximum graphics in Wild Rift.
This device has 8 RAM + 256 ROM and you can expand the RAM
You have plenty of space for everything.
Problems while playing:
- It gets quite hot after playing for a while using the default graphics.
- It is a little uncomfortable to play near the fold of the phone since it is a weak place to press.
- Since it’s not a phone for gaming, it doesn’t have an application to optimize it for video games.
- I think it needs better ventilation, but this is not a device to only play videogames.
Talking about the camera:
Rear cameras: 50 MP and 2 MP depth
Frontal camera: 16 M
I couldn´t upload it with the real resolution of 50MP but it looks really good. Something that I could recommend when you’re taking selfies, It’s better to use the nubia folded and use the camera with the external screen to take better selfies.
Finally:
The nubia Flip 5g is a good device for your daily life, good camera, good processor although a little old, good amount of RAM and ROM, but above all a very elegant design. It is a quality-price device, only with time will you be able to see how long the screen protector lasts.
Thanks for reading and feel free to ask if you have any questions or advice about the review.
