Tingy
I used to have an ASUS RoG G752 and It was a beast, at least it was heavy. U used a laptop and I am currently using another laptop because I lack of space to put a desktop. My current one is a Acer Nitro And if i play games it will get very loud because of its RTX 3070Ti. The noise is okay for me because I always play with headphones.
How is the noise and the heat for the Razor Blade? I had a projector connected to the ASUS and after a few years I found out that if a device is connected to the HDMI or the Thunderbolt Port the dedicated graphics card wouldnt go into standby, so it has been gotten warme than It should have been because I plugged the cable in even though the projector has been off.
