I could say that it’s a good projector with good image and sound quality.
At first glance, the box has a good design and contains specifications about the projector.
Inside the box you will find:
- Xming Episode one (Gray and orange)
- Remote control (AAA batteries not included)
- Power cord
Setting it up is too easy with Google home, you only need to log in with your google account.
The only problem that I found as Mexican is that I didin’t find Latinoamerican Spanish and my country.
By default it focuses and adjusts the size of the projection. But you can do it manually in the settings anyway. Talking about whether it is silent or not, if it’s and quite a lot. Only when you’ve been using it for a while can you hear too much air vent.
On its speaker, it has two outputs which sounds too good for the size it has and if you like it also contains a 3.5 mm jack and an HDMI input
I don’t have a projection screen, but even without it the quality is very good as you can see in the videos.
Finally, I recommend to use it in a very dark place as it lacks power during the day or that you buy blackout curtains. Thanks for the opportunity to review this projector. If you have doubts, I can solve them in the comments.
Thanks for reading.
