Alex14 Just to be sure that I understood correctly. As the title says, do we get to keep the review unit if we’re selected and the review checks all the requirements? Or we need to return it no matter what?
DarkPikaJP Alex14 you’ll keep the item, if the review isn’t up to par, the mods will send you some notes/suggestions.
DarkPikaJP Alex14 no problem. If you haven’t already, you can check out the review guidelines here https://community.heyupnow.com/d/88-heyup-tryout-review-guidelines
