Honor AM510 Bluetooth Speaker - a Speaker that Breaking through the limitation of size
The Design
The Honor Magic Cube is designed as a small cube as a whole, the body Material is made of ABS. on top is a mesh square speaker cover,its dimension is 54mm*54mm*55mm and weighs is about 120g. it is very small even people with small palms can also hold it easily. and also come with a hanging strap. there are Blue, red and white colors to choose.
Charging Port
The Battery
The capacity of battery is 660mAh. on my testing with mostly playing Pop music, achieve 4 hours 3 minutes, this match what the official claims. the charging time is about 1 hours.
Indicator light & Multi-function Button
Connectivity
The Honor AM510 only can play through Bluetooth, and the version is 4.2, although this version of Bluetooth is not the latest one, but on my testing the pairing with my phone is stable, as long as you keep 2 devices within 10 meter between each other.
bass radiator
Features
There is a 3W full-range speaker and frequency response range is 50-25000Hz. The bigger surprise is at the bottom of the speaker. Flip the speaker over and you will see that the bottom of the speaker adopts an independent bass radiator. the sound it projected are full and clear and the small bass radiator surprisingly can generate very deep and punchy bass, with no distortion even at full volume
Stereo Mode
you can paired 2 units of Honor AM510 Speaker to enjoy stereo sound.
Summary
Honor AM510 Bluetooth speaker is definitely a best choice for small speaker with no sound quality compromised. The sound it projected is really stunning me. And it is small in size and very convenient to carry. and the current selling price in Aliexpress is about USD$16.
Product Specifications:
Brand:HONOR
Model: AM510
Material: ABS
Water-Resistant Level: IP54
BT: BT4.2 wireless speaker(support TWS Twins Pairing)
Battery: 660mAh Li-ion Polymer Battery
Charge Port: Micro USB
Standby Time: Auto power off after 30 mins without music playing; Auto power off if unpaired in 5 mins after starting up
Item Size: 5.4*5.4*5.5cm / 2.12*2.12*2.16in
Package Size: 8*12.5*7.3cm / 3.14*4.92*2.87in
Item Weight: 120g / 4.23oz
Package Weight: 180g / 6.34oz
