I definitely go for Samsung ultra 24… let me compare
Let’s talk about their hardware first. So, the Magic 6 Pro features a 6.8-inch LTPO OLED panel with 1280 × 2800 pixels resolution. This display supports up to 120Hz refresh rate, 10-bit colour, Dolby Vision, HDR, and has 5000 nits of peak brightness. On the other hand, the Samsung Galaxy S24 Ultra comes with a 6.8-inch LTPO AMOLED panel with 1440 × 3120 pixels resolution. This display supports up to 120Hz refresh rate, HDR10+, and has 2600 nits of peak brightness.
Coming to their performance, both smartphones are equipped with the Snapdragon 8 Gen 3 SoC. However, with the Galaxy S24 Ultra, you get up to 16GB RAM and 1TB storage. Whereas, the Honor Magic 6 Pro comes in only one storage option – 12GB RAM and 512GB storage. Both smartphones run on Android 14-based UI.For photography, the Honor Magic 6 Pro has a triple camera setup, holding a 50-megapixel main camera with OIS, a 180-megapixel periscope telephoto sensor with up to 2.5x optical zoom, and a 50-megapixel ultrawide lens. For selfies, again it has a 50-megapixel selfie shooter.
The Samsung Galaxy S24 Ultra comes with a quad-camera setup, consisting of a 200-megapixel main camera with OIS, a 10-megapixel telephoto sensor with 10x optical zoom, a 50-megapixel periscope telephoto sensor with 5x optical zoom, and a 12-megapixel ultrawide lens. For selfies, it has a 12-megapixel front camera.
On the battery front, the Honor Magic 6 Pro is packed with a 5600mAh battery that supports up to 80-watt fast charging and 66-watt wireless charging. Whereas, the Galaxy S24 Ultra houses a 5000mAh battery with 45-watt fast charging and 15-watt wireless charging.
So these were all the key specifications of both smartphones. Now, let’s talk about some AI features.
AI features
The Honor Magic 6 Pro is powered by MagicLM for its AI features. We get AI features such as:
AI-Powered Falcon Camera System: This feature is used for motion-sensing and capturing fast-paced action with high accuracy.AI Motion Sensing Capture: This feature predicts and captures decisive moments in ultra-high definition.Magic Ring: This AI features enhances connectivity.Magic Capsule: With the help of this feature, the Magic 6 Pro improves interaction with on-display content.AI Call Privacy 3.0: Lastly, this feature ensures superior call privacy.On the other hand, in the Samsung Galaxy S24 Ultra, we get these AI features:Here are the AI features mentioned in the article:
Circle to Search: The famous C2S feature searches by drawing a circle around any object, text, or image to get information without leaving your current content.Live Translate: This gives real-time speech translation for communication in different languages.Live Call Translate: This gives real-time audio and text translation during calls.Note Assist: It Summarises and formats notes, highlighting key points and action items.Web Assist: It Summarises lengthy articles for easier consumption.Chat Assist: It helps craft messages with appropriate tones and smart replies.AI-enhanced Photography: This includes advanced motion-sensing, depth capture, and enhanced low-light photography.
