Hi the community
Hope all is good for all.
Here my opinion and video about the Vacuum Eureka J12 Ultra
Very usefull and good work at home..
My Youtube video here :
The Connected Robot Vacuum Cleaner with Automatic Drain Base, the EUREKA J12 Ultra is sober, of good manufacturing quality and practical with its automatic and self-cleaning drain solution.
In complete autonomy it will fill itself with water for washing floors, empty itself in dust into the collector, and clean its mops after use.
It is black with control buttons on the upper side to have direct control over the robot if you don’t have the application on hand.
It is also a connected robot vacuum cleaner (via WiFi and the Eureka Robot application) that allows you to control it remotely.
For the contents of the box, we find:
- The EUREKA J12 Ultra robot vacuum cleaner
- A charging station with automatic emptying
- 2 small brushes + two vacuum bags (including 1 pre-installed)
- 1 cleaning brush
- A manual
Concerning the EUREKA J12 Ultra vacuum cleaner:
It is of good manufacturing quality, black in color and has all the characteristics that can be asked of a robot vacuum cleaner.
It has several cleaning programs.
When it comes to an obstacle, the vacuum cleaner slows down and changes direction.
The EUREKA J12 Ultra Robot vacuum has anti-fall sensors.
Under the hood, we find the dust collector with a HEPA filter.
The wheels are quite large, made of rubber with good grip on the ground. (They allow changes of area up to 1.5cm as for example for carpets, parquet floors etc.)
And for the washing part, the EUREKA robot vacuum cleaner is equipped with 2 circular mops that rotate when the J12 robot vacuum cleaner does its job. It is more efficient than classic mops.
Concerning the Automatic and self-cleaning emptying base: It is quite massive and composed of three bins.
The central bin is rather classic, it allows you to put the vacuum bags in order to receive the dust coming from the EUREKA J12 Ultra Robot.
On the top, two other bins are present and allow you to add clean water and collect dirty water.
The base is placed against a wall near an electrical outlet.
It is possible to configure in the Eureka Robot application, on the smartphone, its activation according to our preferences (every time, every other time, every third time, etc.)
In short, the EUREKA J12 Ultra vacuum cleaner with automatic and self-cleaning emptying base does its job completely autonomously with a convincing result.
▶ DuoDetect AI 3D obstacle detection:
The J12 Ultra robot vacuum cleaner features cutting-edge AI technology for smarter navigation, building 3D models of obstacles on the floor to intelligently avoid furniture and other obstacles.
▶ All-in-one base station:
Equipped with automatic mop washing, automatic draining for up to 75 days and automatic mop drying with 55℃ hot wind, the robot vacuum cleaner base station is completely autonomous.
▶ Superior Cleaning for Large Homes:
With 5000Pa powerful suction and 5200mAh durable battery, the J12 Ultra robot vacuum cleaner and mop with dock offers up to 150 minutes of cleaning
