Just bought this new keyboard from Amazon for $70 but I soon realize that TikTok also sells this exact or similar keyboard for half the price.
This is the one from Amazon
This is the one from Tiktok
Sound: With every click it is a satisfying creamy sound, it’s almost like two marbles hitting against each other. Although the sound is very pleasant but if you have a preference of a more quiet keyboards then this is not the one you should get.
Appearance: The customizable RGB lights adds a really nice touch to it because I can change each key with the color of my preference. The case is made out of plastic but it has some weigh to it which I really appreciate as a gamer.
Sensation: You can say I have fairly big fingers and I usually doesn’t like to type on laptops because most of the keys are very close together which makes it easy for me to misclick them. These keyboards spaced perfectly for my fingers, there is a fine gap between each keys so I don’t make a mistake.
