So I just bought a new streaming microphone from Amazon a couple days ago and I wonder what you guys think of this.
That is the mute button you press it to mute/unmute yourself
Review:
Price: I paid roughly $50 for it although it did not come with a Microphone mount so I had to buy it separately and the total came out to $71.
Components: Microphone attached to the stand, mount adapter, USB-C to USB-A cable. I did take the stand off and switched it to the adapter to connected it to the mount if you want to see it the first image shows what the stand looks like.
Appearance: The LED adds a very modern touch to it and if you press the volume button it can switch modes between “full to front” and “front to full”. When the LED is not on, it indicates that you are currently muted. The measurement is 5.5 × 9.3 × 5 inches or 13.97 × 21.08 × 12.7 centimeters so it won’t take up a lot of desk room but I also bought a mount for it just so it didn’t take up any unnecessary space.
Quality: Its got 70dB of noise level, 70dB of signal-to-noise ratio, 6dB of audio sensitivity. The pop filter is also built into the microphone.
Conclusion: It is a good starting microphone to have, as of now I have no problem using it but I would recommend buying something better if you have the budget for it but as of now I will be rocking with this.
