I was very fortunate enough to be one of the people selected to trial the RedMagic GT Watch.
Once it arrived it was a very sleek box that the watch was contained in. It reminded me very much if an Apple Watch packaging. Everything has a place to go in the box.
The watch is solidly built that doesnโt look cheap. The watch strap is comfortable and easy to wear. The straps can be easily swapped if you want to swap for a different strap.
Connecting the watch to the phone was easy. By downloading the red magic app you then scan the QR code it was easy to connect.
There are a number of different exercises that you can track and a limited range of different apps that you can use on the app. The software is quite basic but it does the job. Not 100% on the accuracy of the GPS compared to real life. it has a good battery life lasting for days.
Overall a good basic level watch that has additional features that are useful.
selected
