Ivyisme After reading the known specs on HeyUp, I did a bit more research. Based on layout, a lot may think it’s compatible with the Nintendo Switch but it’s not. Only being compatible with Android and Windows seems a bit lacking. Based on the adapter, which is clearly made for a PC, you would have to be wired into an android device.
Due to poor compatibility, I see this controller being good for someone that enjoys PC gaming. I did read it works well with Steam.
