It will be a feelings review.
I come from LG Watch Urbane W150, it’s an Android Wear Watch that is working perfectly for years.
The first impression for me is RedMagic Watch works pretty well for sports!
Performance: it works perfectly for all the task that it can do.
Battery: it’s so durable, something like 12-14 days per cycle.
Screen: it has a really good size, a little bit big for different wrists.
Buttons: it has two buttons, one for menu and one for sports and works pretty well and responsive.
Conclusion:
Cons:
     \* The app that QR says on initial config is not the correct one, you need to install ZSport.
    \* The initial watch faces are not so elegant.
    \* You cannot install more apps.
Pros:
    \* Works cool for sports and common uses.
    \* It controls Spotify, even when it is closed on your smartphone.
    \* It has notifications for different events: hidration advises, fat consume, stand up notification.
    \* Shows oxygen level on blood.
    \* The main screen navigation is cyclic between watch, music, pulse, sports, ... And it keep on the last selected.
    \* Quality-price relationship is awesome.
    \* Screen brightness is so good.
    xitotix
    Nice review, I was waiting for someone else who has received the watch to compare the pros and cons🤔🤔
    Thanks for sharing this🙌🏻
    xitotix thanks for the review! Just to clarify, you said it’s Android Wear, but you can’t download more apps onto it?
      Heyo
      I think you got confused. He mentioned he had an LG watch that ran Android Wear, but this Redmagic watch doesn’t have that feature🙈🙈
        xitotix buena reseña ,esperamos que en el futuro sean aún mejores 👍
        Nice review, thanks for sharing
        Gracias por compartir tu Review me gustaría ser otro ganador
