So I’ve been streaming a lot recently on a game and noticed that the laptop that I use gets very over heated. As a result I went to Amazon and bought a laptop cooler. Unfortunately I don’t have any experiences with these kind of things so I ended up buying the one with the most fans, it was 11.
This is what it looks like
Appearance: it is 10 RGB settings and you can turn it off as well. the lights inside the fans were not changeable
Material: It feels like cheap plastic and if you have it on when moving it, your fingers/finger nails could end up slipping through the brackets and damage the fans as a result.
Packaging: It was a brown box with the exact design but black and white on the cover. Once you open it there is a sheet of bubble wrap surrounding it with a little instruction booklet.
Noise: it is quite quiet but not quite enough to ignore the noise.
Productivity: It does in fact cool down the laptop a bit and when you are just working on simple documents it doesn’t heat up at all with it.
Here are the temperature from before and after with the cooler:
BEFORE:
AFTER:
Although it did decrease the temperature by only a couple celsius, do you think it was worth 30 bucks?
