Maintenance of the Tri-Cut Generation 2 of Dreame:
First, remove the roll brush cover on the robot. Then, remove the Tri-Cut roll brush and clean any hair from the brush. Next, unplug the square end cover and remove the rubber strips. Use a small brush to clean the gaps.
Important! The main body must not be washed with water. However, the rubber strips can be washed. After cleaning, reinstall the rubber strips. These strips are a cost-effective part and should be replaced every 6 months.
Finally, reinstall the brush and cover.
For those that are interested i leave a link from AliExpress. https://s.click.aliexpress.com/e
_DeHUE9P
