So I received the true wireless open earbuds the design looks sleek the case is heavy and looks durable if dropped by accident. Paired seamlessly. The sound is crystal clear. I like to listen to my music loud so this was important however no bass. I did have to recalibrate my listening sounds in settings because it was too low. The Battery does last a long time without charging. The charging cord is a C which is great if your cellphone is as well it is fast chargingas well. Range away from the case is pretty far. Call quality it’s superb person on the other end can hear you loud and clear and you can hear them
Now heres what I feel its lacking Wearing these around others they will hear what ur listening to or what the caller on the phone is saying. I also haven’t found anything that tells you how much charge you have left except when ur under 50% it shows under your connected Bluetooth. The ear fit feels kinda snug but not comfortable should add different ear pieces cause I have small ears and it still feels like it’s going to pop off. COMPARED TO MY GALAXY PROS these lack the galaxy pros definitely sound better if u want bass with your music. I’d rate this product a 4. The price I feel is a bit much. They should add a find my bud feature as well as a feature for case and buds to tell u what charge percentage your at.
