There’s NOTHING (ear stick) like this.
I’m working from home these days and my family are all overseas so i often videocall them and to have a smooth conversation I need a nice good quality airbuds. I had Airpod Pro which is $249.99 and now I got this Nothing Ear (stick) Wireless buds which is only $119 on amazon for tryout. My rating would be 4 out of 5. You’ll see why if you continue reading this till the end.
UNBOXING
Sharing with you my unboxing experience. I wasn’t expecting that little box has the ear buds. I love how they use paper and less plastic on the packaging. The white and red color choice for the case is a perfect combination. Look at the Cylinder design case that you can twist to access the ear stick. It’s very satisfying!
UNBOXING VIDEO ▶️
LIKE AND DISLIKES
I really like the design, they are really gorgeous. Very aesthetic! You can put it on your purses like just any make-up. I like how the cylinder design case and not the same as others. But i hope it comes with a bag or pouch for it because im worried that the case will get scratch. The controls are a bit vague and not fully responsive. All in all it has its positives and negatives but a great product so far. The sound quality is very impressive for its size. It has impressive bass and clarity in the highs. It has its own easy to use app that you can download and find your earbuds if you lose them. I like how its water-resistant to the point that it can prevent rain, splashing water or sweat. But ofcourse not directly to the water since it’s not waterproof. Perfect companion during workout or while cooking.
ENJOYING MY NOTHING EAR(stick)
COMPARISON
I’m comparing it with my Airpods Pro 2 since that’s what I have been using before this Nothing Ear (stick) wireless buds came.
Nothing Ear is smaller than Airpods based on height by 0.07 inch. It has better shape and feel than the Airpods Pro 2 though both are comfortable that you’ll forget you’re wearing them. We all know that when it comes to Apple Airpods, you will need an Apple device to get the most from Apple Airpods but with NOTHING Ear stick you just need to download the companion app. The app is very helpful because you can easily access all of its features such as find my earbuds in case you lose them, updating firmware, and adjustments to the touch controls. You can also adjust the noise cancelling and transparency modes, or adjust the sound of the earbuds using the in-app equalizer. How good is that!
SUGGESTIONS
I know the price will definitely increase but nowadays most of the consumer will prefer to have a wireless charger or if not atleast a longer cable charger. Cause the one included in the box is generic. It’s very short. I also recommend adding a pouch or a rubber cover for protection in case of drop. I don’t think there’s one like that for this specific model. It will be hard to look for one.
PRICING
Exceptional value for reasonable price. The quality and finish of the product doesnt look cheap at all. And yes! There’s “NOTHING” like this!
