UxiaCesSantos It’s my birthday in the next few months and I’m looking for a digital watch to buy. Would you like to know which ones you recommend?
Menguelez UxiaCesSantos Digital watch you mean smartwatch? It depends of your use. Maybe with a smartband you can get you want. Do you know what options do you want in the smartwatch? Like podometer, blood presure, notifications, calls, nfc…
EvilZelda UxiaCesSantos I would suggest it might have to see how much budget that you are considering first, I’d say if your phone is IOS, then definitely apple watch would be a match. But honestly, samsung watch is good too.
UxiaCesSantos Menguelez Yes, I am looking for a clock that allows me to answer messages, receive calls and that has the option of calculating kilometers.
Menguelez UxiaCesSantos well, answer messages only in wear os, by the way in a little screen is a bit unsatisfactory. Wear os is for android, what phone do you have?
Menguelez UxiaCesSantos then if you use IOS the best option is an Apple Watch. But if you want an economic option I think it wibe a great option one HUAWEI WATCH FIT 2
Helen UxiaCesSantos For me, if you are using the IOS and want to receive and answer calls with the smartwatch, I will recommend the Apply Watch SE;)
