HAKII MIX is a headband and headphones at the same time and that’s great.
It is very comfortable and ergonomic and adapts to all head shapes, thanks also to the adjustment bands supplied inside.
The packaging is sensational, I really like the blue and black together and I really like the manga-style designs, they make everything very playful, among other things, the external materials of the box are all of excellent quality with the writing in relief.
Inside, as soon as we open the box, we can find a first guide that reminds us to assemble and wear Hakii in the correct way to have a correct sound release and cleaning.
The adjustment bands are essential to adapt Hakii to the size of your head and I must say that they are very ergonomic and comfortable.
In addition to Hakii inside we can find some nice anime/manga style stickers that I always find very pleasant to find when I buy a product and a comfortable case to take Hakii with us wherever we want.
Inside we can also find the appropriate USB charging cable.
Functionality:
Hakii is very easy to use and turn on by holding down the power button the device will be ready and it will start flashing communicating with you with very pleasant sounds.
If it is not connected it switches off automatically and it is very easy to connect it to any device using bluetooth.
The sound is clear and mild.
The thing that amazed me the most is that hardly anyone next to you will be able to hear what you are listening to and you are perfectly isolated with your audio from the rest of the world and I find it fantastic, nobody will be distracted by what you are listening to.
The unit also has the ability to adjust audio directly from the device, even when on the go.
Another surprising feature is that you can use Hakii for your hands-free calls, and it works amazingly after testing it, its two microphones reduce noise and allow clear and clear conversations.
Hakii boasts a long-lasting charge and the ability to listen to music for up to eight.
In short, if you are looking for something to train and which allows you to move but without giving up impeccable sound quality, you know which product to choose.
You no longer have to worry about losing your headphones as they will be secure on your head and your ears will thank you.
