ZolikaKele If you are looking for an iPhone for $600 maybe the options are a 13 pro or 14 pro (including the pro max versions), Although the 14 pro will depend on luck due to its price factor.
If we look for alternatives in other brands, perhaps I could recommend a Oneplus Ace 3, which at least in Mexico I have seen for up to 400-450 dollars. And given its features, I think it’s a great option for a considerably good price.
If you don’t like Oneplus maybe we could mention:
- Google pixel 8 pro
- Nubia z60s pro (Hopefully the ultra)
- Samsung S23 fe and s24 fe
