This is my first time trying non-inear headphones and I am really pleasantly surprised!
I start from the packaging because it has a very sober, elegant and even a little witty visual impact with the manga. The combination of blue and black colors is excellent (so, the packaging already impressed me! 🤣 The initial impression is thus of a good quality object even if you haven’t actually seen it yet.
Once the container is opened we find the real box in a very elegant blue color and inside, as soon as you open it, the first thing you find as a “welcome” is a quick instructions leaflet, how to assembly and how the headphones should be worn. Under the practical instructions we find the part that interests us most:
- 2 bands different sized to have the opportunity for the best fit based on the size of the head
- The band with the 2 headphones
- a handy bag for storing the headband
- the recharging usb cable type-C
- More detailed instruction booklet
Assembling the headbands to the headphones is very simple also helped by the letters “L” and “R” for the right positioning and by the slightly magnetic final part of the adjustment band for a better grip. Once worn, it is very light, soft and ergonomic.
To turn it on, simply press the button on the left side and the connection to the bluethoot is very fast, on the bluetooth of your device you will immediately find Hakii MIX for pairing. Excellent and stable connection up to 10 meters without barriers.
Also on the left side, near the power button, there are small buttons for the various functions. On the right side there is the small volume button.
When I first put these headphones on I was fascinated by the clear and clean sound, I could hear the music even with my ears free. While not keeping the volume very low, those sitting next to me did not hear my music. Having hands free, ears free and listening to music without bothering those close to you is a fantastic feeling!
I tried making and receiving calls, again nothing to complain about, clean and clear sound, microphone with reduction of surrounding noise, the interlocutor also heard me very well and clearly.
Fast and long-lasting charging, when fully charged you can listen to music up to 8 hours.
Well how to consider this experience? Fantastic! I recommend using these headphones for any occasion, especially for those who want to be completely free!
