So I’ve done a review on this already 3 months ago but recently I’ve experienced problem with this keyboard so I’m here to share it with you.
This is what the keyboard looks like:
Sound: After many months of typing on it I still haven’t get tired of hearing it, the creamy noise from the keys do not fade out after using it for a while which is good. But they are gaming keyboards and if you are trying to play games that strongly requires communication than I would not suggest using this for gaming, from my experience most people find it annoying and loud.
Appearance: There are many RGB settings and you can customize the lights. You can also change the lights around each key for a different color combination, but I like to keep the colors sliding to the right like waves.
Sensation: It is not hard to press the keys, I like to feel when I’m actually pressing the keys. If you don’t know what I mean then think about typing on a laptop, the keys are dense, thin, and light, most of the times I don’t even know which one I pressed and which ones I missed because. But with theses keys I can easily noticed when I press each key. This is just my personal preference, each person is different. Lastly, each key is curved inwards so that when your finger rest upon it sits in place and provided the bare minimum of your fingers slipping towards other keys.
Problem: Since I use this keyboard for gaming a lot and especially Fortnite, I press w,a,s,d a lot to. Over time I noticed that the keys I press the most for Fortnite, either becomes less responsive or too responsive to the point that when you press the key once, it’ll spit out a lot of them at once.
