Look/Presentation- Sleek case pocketable case. The earbuds itself have a glossy finish that doesn’t pick up fingerprints( a plus in my books)
App- Next to the sound the app is the best. The app give you control over the sound and lets you tune your own EQ. Even coming with some preset EQ’s from Grammy winning producers. Also within the app is what Soundcore calls HearID. Basically it tests your ears to give you a personalized EQ. You can control the noise cancellation and transparency mode, which touch controls you want on your buds and more within the app. It’s the best I’ve seen so far.
Battery- The Battery life is not bad, it’s enough to get you through the day. 8 hours on the buds and 32 hours on the case and you can track the battery life through the app.
Fit and comfort- The earbuds come with 4 ear tips and 4 ear wings. I highly highly recommend taking some time and going through the different sizes to get the best sound, noise cancellation and comfort, there is an ear for test in the app, I ended up going with the medium ear tips with the large ear wings. Overall they are pretty comfortable just not good for side sleepers.
Sound- The sound. Now Soundcore is known for giving that bass, but I was not expecting THIS!!!! The bass, the treble and the clarity is some of the best I’ve heard in a while. The best part of the sound is that with ANC on the bass doesn’t muddy up the sound. It’s constant across all modes. With the addition of the app you have the option to make it sound however you like,but either way it’s going to put a big smile on your face
