At first glance, this electric tire inflator by OAK & IRON could be mistaken for a small power station but in fact is used to inflate tires on Cars, Motorcycles, Bicycles, footballs and much more.
Inside the box contains:
Tire Inflator
Press- on valve
Twist-on valve
Presta valve
Needle valve adaptor
Adapting valve
Type-C charging cable
And Storage pouch
Design/Features
Personally, I really like the design of the OAK & IRON One Portable Tire Inflator, the body Is made from plastic but still manages to look and feel premium. The black finish and green boarder around the physical buttons is a touch
The top of the device has the air hose interface, vents, a 100 Lumen LED light which is a great feature especially if you have to use the inflator in a low light environment, and a USB-C charging port.
The back of the device shows the steps to pump up your tires and the product information.
The display shows the battery level indicator in the top left corner, the current pressure, mode indicator ( whether you’ve selected, Car, Motorcycle, Bike, Balls) and the preset pressure.
The controls on the OAK & IRON One Portable Tire Inflator are straight forward and very easy to use. The minus (-) and plus (+) buttons allow you to adjust the pressure in the manual mode, the power/pump button turns on the device and starts/stops the pumping. The Mode button switches between Car, Motorcycle, Bicycle, Ball and Manual and the light button turns the light on or off.
Rating: 5
Battery/Charging
Powering the OAK & IRON One is a 7,800mAh battery which takes 3.5 hours to be fully charged. OAK & IRON One can give you 300 days of stand-by power which is great, which means it will be ready to use as and when you need it.
Rating: 5
Overall thoughts?
Using the OAK & IRON One has been simple, easy and very straight forward which took 3 steps: start the inflator, set the target air pressure or selecting the mode (Car, Motorcycle, Bicycle, Ball), connect the tube to the tire and press the pump button.
I really like the design and feel of the OAK & IRON One, it’s cord free, portable and has a great battery in stand-by mode. There are some good features such as the LED Light, adding a USB-C charging port and the tire inflator automatically stopping once the preset pressure value was reached. One thing to bear in mind is the OAK & IRON One cannot be used when charging.
Overall I’m very happy with the OAK & IRON One Portable Electric tire inflator which will replace the current 12V analogue tire inflator I have in the boot of my car.
Overall rating: 5
Price: $99/£81 Kickstarter
Retail: $149/£122 - Kickstarter: $109/£89
OAK & IRON ONE
