Please check out my unboxing video by following a link below:
Oak & Iron One Battery Tire Inflator Unboxing Video
If you’re looking for an indispensable addition to your car safety kit, look no further than the Oak & Iron tire inflator. Not only is it a breeze to use, but you won’t have to worry about connecting it to your cigarette lighter for power. With just the push of a button, you can easily check and adjust your tire pressure to the desired psi.
Although the valve connector may leak a few psi when disconnected, I find that simply setting the pressure to 2psi higher and double-checking each tire with a separate gauge does the trick. And trust me, this is one tire inflator you don’t want to skip out on.
While it may not have popped up in your Google search for the best portable tire inflator, it should have. Not only is it faster and easier to use than my other portable tire inflator, but the hoses provided are top-of-the-line quality - no cheap ones in sight. Just be sure to let it cool off for 5-10 minutes between tires, and you’ll be good to go. All in all, I highly recommend this tire inflator!
