Hi all
Here my youtube video about the OAK & IRON One Inflator.
Hope it will be helpful for you..
https://youtu.be/QlvdR7gaR7U
The OAK & IRON One Battery Tire Inflator air compressor is not very large in size and can therefore be put in a corner of the car trunk, the glove compartment or a household closet if necessary.
It has the shape of a big powerbank.
Clean and well finished as a product, it is intuitive to use. The entire outer part of the OAK & IRON inflator is made of plastic.
Practical, the whole package can be stored in the pouch that is included in the package.
To recharge the OAK & IRON portable electric air Compressor, simply connect it to an AC adapter as for smartphones with a USB type C cable.
For operation, it is sufficient to
1/ Start the OAK & IRON compressor
2/ Choose what you want to inflate
3/ If necessary adjust the pressure you want
4/ Put the tip on the valve of the car (or ball / bicycle wheel โฆ)
5/ press the start button
Inflation then begins and stops automatically once the requested pressure is reached. (the on-board computer of my Mรฉgane 3 indicates the same pressure)
The package consists of:
- The OAK & IRON One Battery Tire Inflator
- Several tips for car / balloons โฆ
- A notice
- A micro USB charging cable
- A storage pouch
Have a good day
Tof..
