The OAK & IRON WAVE Pro Smart Outdoor Inflator is a game-changer for anyone who loves outdoor activities. With its ability to inflate a wide range of equipment, including SUP, kitesurfing kites, and inflatable boats, the WAVE Pro is a versatile tool that makes outdoor adventures more convenient than ever before.
The WAVE Pro has a sleek and simple design, with a large plastic rectangle body and a sturdy handle for easy carrying. It’s lightweight, weighing only 2.38kg, and has dimensions of 355173119mm, making it compact enough to take on the go. What’s more, the WAVE Pro is cordless, thanks to its built-in 6,000 mAh battery, making it the perfect portable inflator for outdoor use.
Inside the box, you’ll find the OAK & IRON Wave Pro portable inflator, an air hose with various adapters for different inflatable devices, a few silicon washers to help with sealing, an attached 12V (cigarette lighter) cable, a USB cable for recharging the battery, a manual, quick-start guide, and some stickers. With these accessories, you’ll be able to inflate and deflate your equipment quickly and easily.
The inflator’s user-friendly design is evident in the large display on the front panel, which shows important information such as battery life and pressure. The display is accompanied by four simple buttons, which make it easy to adjust settings and switch between inflation and deflation modes.
Overall, the OAK & IRON WAVE Pro Smart Outdoor Inflator is a fantastic investment for anyone who enjoys outdoor activities. With its versatile design and easy-to-use features, the WAVE Pro makes inflating and deflating outdoor equipment a breeze. So why wait? Get your hands on the OAK & IRON WAVE Pro Smart Outdoor Inflator today and experience the ultimate convenience in outdoor inflators!
Please check out the unboxing video and subscribe to my channel:
