1-piece portable chair | 5-second unfold | 1.45Kg/3.3lbs | 300lbs capacity | Alu-frame | Embracing seat | 12" seating height
Have you heard of the Sitpack Campster 2? It’s the latest product from Rest, and it’s perfect for anyone who loves spending time outdoors. Recently its crowdfunding campaign has been funded with $ 685,083 by 6,399 backers!
The Sitpack Campster 2 is a portable, lightweight seat you can take with you on all your adventures. It’s made from durable materials and is designed to be comfortable and stable, so you can sit back and relax no matter where you are.
One of the best things about the Sitpack Campster 2 is how easy it is to set up. You can have it up and ready to use in just a few seconds, which makes it perfect for camping trips, picnics, or even just a day out in the park. If you’re someone who loves spending time outdoors, then the Sitpack Campster 2 is definitely worth checking out.
Cast your wish for this awesome product if you are interested in it. We will open the tryouts once it gains enough wishes, and be first to notify the users who are interested in it.
