Showcase Video | Official website
The RedMagic 8 Pro is a gaming phone ready to dominate the market. It is marketed as a high-performance device designed specifically for gaming enthusiasts.
The phone features a 6.65-inch AMOLED display with a 144Hz refresh rate, making it one of the smoothest displays available on any smartphone. The display also supports HDR10+ for better contrast and color accuracy.
Under the hood, the RedMagic 8 Pro is powered by a Snapdragon 8 2nd Gen processor, which is paired with either 8GB or 12GB of RAM and 128GB or 256GB of storage. This means that the phone is capable of handling even the most demanding games with ease.
In terms of design, the RedMagic 8 Pro has a sleek and modern look, with a customizable LED strip on the back that can be programmed to display different patterns and colors. The phone also has built-in shoulder triggers that can be used to control games more easily.
One of the standout features of the RedMagic 8 Pro is its cooling system. The phone has an active cooling fan that helps dissipate heat, which can be particularly helpful during extended gaming sessions. The cooling system also helps maintain high performance levels and prevent throttling.
The phone runs on RedMagic OS, which is based on Android 10. The OS includes a number of gaming-focused features, such as a Game Space app that allows you to customize performance settings for different games.
In terms of cameras, the RedMagic 8 Pro has a triple-lens setup on the back, including a 50-megapixel primary sensor, an 8-megapixel ultra-wide sensor, and a 2-megapixel macro sensor. On the front, there is a 20-megapixel selfie camera.
The phone also has a large 6,000mAh battery with support for fast charging up to 65W, which should provide ample battery life for extended gaming sessions.
Overall, the RedMagic 8 Pro is a high-performance gaming phone with a sleek design, a smooth display, powerful hardware, and an effective cooling system. While it may not be the best choice for non-gamers, those who are serious about mobile gaming will likely find a lot to like about this device and will be winning a lot of games.
